[postgis-tickets] [PostGIS] #5559: Just noticed manual-dev is not accessible
PostGIS trac at osgeo.org
Sat Sep 30 15:47:08 PDT 2023
  Reporter:  robe           |      Owner:  robe
      Type:  defect         |     Status:  new
  Priority:  blocker        |  Milestone:  PostGIS 3.5.0
 Component:  documentation  |    Version:  master
Resolution:                 |   Keywords:
Comment (by robe):
 It's not the disk space at issue.  Just triggered a rebuild and it's still
 messed up. When I look at view source I see lots of text, but it's not
 showing.
 The headers look all screwed up.  Like compared to 3.4, it has <?xml
 version="1.0" encoding="UTF-8" standalone="no"?>  as the first line. This
 is not an xml document. That shouldn't be there. Unfortunately just
 removing that doesn't fix the issue.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5559#comment:2>
