[PostGIS] #5707: slow cb_getEdgeByFace seems like missing value for bbox parameter
PostGIS trac at osgeo.org
Mon Apr 1 21:03:19 PDT 2024
  Reporter:  Lars Aksel Opsahl  |      Owner:  strk
      Type:  enhancement        |     Status:  new
  Priority:  medium             |  Milestone:  PostGIS 3.4.3
 Component:  topology           |    Version:  3.4.x
Resolution:                     |   Keywords:
Comment (by Lars Aksel Opsahl):
 Here are the table def
 \d "tmp_dyrkbarjord_04_t3_d_005".edge_data;
                                              Unlogged table
 "tmp_dyrkbarjord_04_t3_d_005.edge_data"
        Column        |           Type            | Collation | Nullable |
 Default
  edge_id             | integer                   |           | not null |
 nextval('tmp_dyrkbarjord_04_t3_d_005.edge_data_edge_id_seq'::regclass)
  start_node          | integer                   |           | not null |
  end_node            | integer                   |           | not null |
  next_left_edge      | integer                   |           | not null |
  abs_next_left_edge  | integer                   |           | not null |
  next_right_edge     | integer                   |           | not null |
  abs_next_right_edge | integer                   |           | not null |
  left_face           | integer                   |           | not null |
  right_face          | integer                   |           | not null |
  geom                | geometry(LineString,4258) |           | not null |
 Indexes:
     "edge_data_pkey" PRIMARY KEY, btree (edge_id)
     "edge_data_abs_next_left_edge_idx" btree (abs_next_left_edge)
     "edge_data_abs_next_right_edge_idx" btree (abs_next_right_edge)
     "edge_end_node_idx" btree (end_node)
     "edge_gist" gist (geom)
     "edge_left_face_idx" btree (left_face)
     "edge_right_face_idx" btree (right_face)
     "edge_start_node_idx" btree (start_node)
 Foreign-key constraints:
     "end_node_exists" FOREIGN KEY (end_node) REFERENCES
 tmp_dyrkbarjord_04_t3_d_005.node(node_id)
     "left_face_exists" FOREIGN KEY (left_face) REFERENCES
 tmp_dyrkbarjord_04_t3_d_005.face(face_id)
     "next_left_edge_exists" FOREIGN KEY (abs_next_left_edge) REFERENCES
 tmp_dyrkbarjord_04_t3_d_005.edge_data(edge_id) DEFERRABLE INITIALLY
 DEFERRED
     "next_right_edge_exists" FOREIGN KEY (abs_next_right_edge) REFERENCES
 DEFERRED
     "right_face_exists" FOREIGN KEY (right_face) REFERENCES
     "start_node_exists" FOREIGN KEY (start_node) REFERENCES
 Referenced by:
     TABLE "tmp_dyrkbarjord_04_t3_d_005.edge_data" CONSTRAINT
 DEFERRED
 DEFERRED
 and yes it does not use the index with simple query either
  explain analyze              SELECT edge_id,left_face,right_face,geom
 FROM "tmp_dyrkbarjord_04_t3_d_005".edge_data WHERE ( left_face = 0 )  OR
 (right_face = 0 )
                                                     QUERY PLAN
  Seq Scan on edge_data  (cost=0.00..30625.22 rows=94479 width=162) (actual
 time=0.017..126.493 rows=78609 loops=1)
    Filter: ((left_face = 0) OR (right_face = 0))
    Rows Removed by Filter: 243439
  Planning Time: 0.161 ms
  Execution Time: 128.823 ms
 (5 rows)
 Just to sure I rerun a new vacuum
 VACUUM (analyze, verbose) "tmp_dyrkbarjord_04_t3_d_005".edge_data;
 INFO:  00000: vacuuming "tmp_dyrkbarjord_04_t3_d_005.edge_data"
 INFO:  00000: scanned index "edge_data_pkey" to remove 21147 row versions
 DETAIL:  CPU: user: 0.04 s, system: 0.01 s, elapsed: 0.05 s
 INFO:  00000: scanned index "edge_data_abs_next_left_edge_idx" to remove
 21147 row versions
 DETAIL:  CPU: user: 0.02 s, system: 0.02 s, elapsed: 0.05 s
 INFO:  00000: scanned index "edge_data_abs_next_right_edge_idx" to remove
 21147 row versions
 DETAIL:  CPU: user: 0.02 s, system: 0.02 s, elapsed: 0.04 s
 INFO:  00000: scanned index "edge_gist" to remove 21147 row versions
 DETAIL:  CPU: user: 0.03 s, system: 0.03 s, elapsed: 0.06 s
 INFO:  00000: scanned index "edge_left_face_idx" to remove 21147 row
 versions
 DETAIL:  CPU: user: 0.03 s, system: 0.01 s, elapsed: 0.04 s
 INFO:  00000: scanned index "edge_right_face_idx" to remove 21147 row
 versions
 INFO:  00000: scanned index "edge_start_node_idx" to remove 21147 row
 versions
 DETAIL:  CPU: user: 0.02 s, system: 0.01 s, elapsed: 0.04 s
 INFO:  00000: scanned index "edge_end_node_idx" to remove 21147 row
 versions
 DETAIL:  CPU: user: 0.01 s, system: 0.03 s, elapsed: 0.04 s
 INFO:  00000: "edge_data": removed 21147 row versions in 860 pages
 DETAIL:  CPU: user: 0.00 s, system: 0.00 s, elapsed: 0.00 s
 INFO:  00000: index "edge_data_pkey" now contains 322048 row versions in
 8461 pages
 DETAIL:  21147 index row versions were removed.
 177 index pages have been deleted, 102 are currently reusable.
 CPU: user: 0.00 s, system: 0.00 s, elapsed: 0.00 s.
 INFO:  00000: index "edge_data_abs_next_left_edge_idx" now contains 322048
 row versions in 8488 pages
 175 index pages have been deleted, 100 are currently reusable.
 INFO:  00000: index "edge_data_abs_next_right_edge_idx" now contains
 322048 row versions in 8429 pages
 170 index pages have been deleted, 94 are currently reusable.
 INFO:  00000: index "edge_gist" now contains 322048 row versions in 12886
 pages
 1298 index pages have been deleted, 1202 are currently reusable.
 INFO:  00000: index "edge_left_face_idx" now contains 322048 row versions
 in 8397 pages
 1035 index pages have been deleted, 1015 are currently reusable.
 INFO:  00000: index "edge_right_face_idx" now contains 322048 row versions
 in 8483 pages
 692 index pages have been deleted, 674 are currently reusable.
 INFO:  00000: index "edge_start_node_idx" now contains 322048 row versions
 in 8452 pages
 178 index pages have been deleted, 102 are currently reusable.
 INFO:  00000: index "edge_end_node_idx" now contains 322048 row versions
 in 8472 pages
 167 index pages have been deleted, 93 are currently reusable.
 INFO:  00000: "edge_data": found 207 removable, 8790 nonremovable row
 versions in 871 out of 51589 pages
 DETAIL:  0 dead row versions cannot be removed yet, oldest xmin: 533943927
 There were 7489 unused item identifiers.
 Skipped 0 pages due to buffer pins, 20492 frozen pages.
 0 pages are entirely empty.
 CPU: user: 0.21 s, system: 0.19 s, elapsed: 0.41 s.
 INFO:  00000: "edge_data": truncated 51589 to 50631 pages
 DETAIL:  CPU: user: 0.10 s, system: 0.01 s, elapsed: 0.11 s
 INFO:  00000: vacuuming "pg_toast.pg_toast_2235142925"
 INFO:  00000: index "pg_toast_2235142925_index" now contains 0 row
 versions in 1 pages
 DETAIL:  0 index row versions were removed.
 0 index pages have been deleted, 0 are currently reusable.
 INFO:  00000: "pg_toast_2235142925": found 0 removable, 0 nonremovable row
 versions in 0 out of 0 pages
 DETAIL:  0 dead row versions cannot be removed yet, oldest xmin: 533943928
 There were 0 unused item identifiers.
 Skipped 0 pages due to buffer pins, 0 frozen pages.
 INFO:  00000: analyzing "tmp_dyrkbarjord_04_t3_d_005.edge_data"
 INFO:  00000: "edge_data": scanned 50631 of 50631 pages, containing 322048
 live rows and 0 dead rows; 300000 rows in sample, 322048 estimated total
 rows
 and rerun this simple sql still with seq scan
 explain analyze              SELECT edge_id,left_face,right_face,geom FROM
 (right_face = 0 )
                                                     QUERY PLAN
  Seq Scan on edge_data  (cost=0.00..30146.22 rows=94523 width=162) (actual
 time=0.017..120.990 rows=78609 loops=1)
  Planning Time: 0.775 ms
  Execution Time: 123.262 ms
 (5 rows)
 Even if rewrite the sql so uses the indexes, we never see anything close
 the the performance by using the bbox parameter
 "tmp_dyrkbarjord_04_t3_d_005".edge_data WHERE left_face = 0 UNION  SELECT
 "tmp_dyrkbarjord_04_t3_d_005".edge_data WHERE right_face = 0 ;
 QUERY PLAN
  HashAggregate  (cost=46293.27..47311.23 rows=101796 width=44) (actual
 time=151.638..164.441 rows=78609 loops=1)
    Group Key: edge_data.edge_id, edge_data.left_face,
 edge_data.right_face, edge_data.geom
    ->  Append  (cost=1189.75..45275.31 rows=101796 width=44) (actual
 time=14.022..91.000 rows=101787 loops=1)
          ->  Bitmap Heap Scan on edge_data  (cost=1189.75..18353.36
 rows=35139 width=162) (actual time=14.021..39.493 rows=35127 loops=1)
                Recheck Cond: (left_face = 0)
                Heap Blocks: exact=8953
                ->  Bitmap Index Scan on edge_left_face_idx
 (cost=0.00..1180.96 rows=35139 width=0) (actual time=10.924..10.925
 rows=35127 loops=1)
                      Index Cond: (left_face = 0)
          ->  Bitmap Heap Scan on edge_data edge_data_1
 (cost=2273.01..25395.02 rows=66657 width=162) (actual time=11.529..47.015
 rows=66660 loops=1)
                Recheck Cond: (right_face = 0)
                Heap Blocks: exact=15257
                ->  Bitmap Index Scan on edge_right_face_idx
 (cost=0.00..2256.35 rows=66657 width=0) (actual time=9.506..9.506
 rows=66660 loops=1)
                      Index Cond: (right_face = 0)
  Planning Time: 0.261 ms
  Execution Time: 168.322 ms
 (15 rows)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5707#comment:1>
