[PostGIS] #5699: ERROR: XX000: SQL/MM Spatial exception - geometry crosses an edge
PostGIS trac at osgeo.org
Sun Apr 7 12:34:05 PDT 2024
  Reporter:  Lars Aksel Opsahl  |      Owner:  strk
      Type:  defect             |     Status:  assigned
  Priority:  medium             |  Milestone:  PostGIS 3.4.3
 Component:  topology           |    Version:  3.4.x
Resolution:                     |   Keywords:  robustness
Comment (by strk):
 For the record, Dr.JTS confirmed the GEOS bug with RelateComputer:
 https://github.com/libgeos/geos/issues/968#issuecomment-2041134101
 It's to be noted that fixing the GEOS bug would still not give us a
 solution to the problem of being able to load the incoming line into the
 existing topology.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5699#comment:15>
