[PostGIS] #5709: ST_ChangeEdgeGeom fails to update face MBR when movement is smaller than float4
PostGIS trac at osgeo.org
Mon Apr 8 10:31:57 PDT 2024
float4
  Reporter:  strk      |      Owner:  strk
      Type:  defect    |     Status:  new
  Priority:  medium    |  Milestone:  PostGIS 3.4.3
 Component:  topology  |    Version:  3.4.x
Resolution:            |   Keywords:
Comment (by strk):
 The problem, like in #5709, is that lwgeom_get_bbox gets an approximaged
 bounding box from the serialized representation of the geometry:
 +psql:test.sql:28: DEBUG:  [topo/lwgeom_topo.c:lwt_ChangeEdgeGeom:3569]
 BBOX of changed edge did not change
 Paul, Regina: should we maybe stop reding that lamed-down box from the
 serialized representation when deserializing into LWGEOM ?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5709#comment:2>
