[SCM] PostGIS branch master updated. 3.4.0rc1-1083-gb123d48a7
Mon Apr 8 11:00:31 PDT 2024
the project "PostGIS".
       via  b123d48a7b6bf127120dd3eca5d892cf95180c73 (commit)
      from  96914caf8e81b9a7a255dfc2eece6be59e2f297f (commit)
revisions in full, below.
commit b123d48a7b6bf127120dd3eca5d892cf95180c73
Author: Sandro Santilli <strk at kbt.io>
Date:   Mon Apr 8 19:59:15 2024 +0200
    Make sure ST_ChangeEdgeGeom gets a fit view on edge's bounding boxes
    Reference #5704 in master branch (3.5.0dev)
    Includes regression testcase
diff --git a/liblwgeom/topo/lwgeom_topo.c b/liblwgeom/topo/lwgeom_topo.c
index 370c82447..570f449a5 100644
--- a/liblwgeom/topo/lwgeom_topo.c
+++ b/liblwgeom/topo/lwgeom_topo.c
@@ -3512,8 +3512,12 @@ lwt_ChangeEdgeGeom(LWT_TOPOLOGY* topo, LWT_ELEMID edge_id, LWLINE *geom)
   --       would be larger than the old face MBR...
-  const GBOX* oldbox = lwgeom_get_bbox(lwline_as_lwgeom(oldedge->geom));
-  const GBOX* newbox = lwgeom_get_bbox(lwline_as_lwgeom(geom));
+  LWGEOM *oldgeom = lwline_as_lwgeom(oldedge->geom);
+  LWGEOM *newgeom = lwline_as_lwgeom(geom);
+  lwgeom_refresh_bbox(oldgeom); /* Ensure we use a fit mbr, see #5709 -- TODO: fix this at lower level */
+  lwgeom_refresh_bbox(newgeom); /* Ensure we use a fit mbr, see #5709 -- TODO: fix this at lower level */
+  const GBOX* oldbox = lwgeom_get_bbox(oldgeom);
+  const GBOX* newbox = lwgeom_get_bbox(newgeom);
   if ( ! gbox_same(oldbox, newbox) )
     GBOX* updatedBox;
diff --git a/topology/test/regress/st_changeedgegeom.sql b/topology/test/regress/st_changeedgegeom.sql
index 7822035e0..7f2605e4e 100644
--- a/topology/test/regress/st_changeedgegeom.sql
+++ b/topology/test/regress/st_changeedgegeom.sql
@@ -150,3 +150,39 @@ ROLLBACK;
 SELECT topology.DropTopology('city_data');
+-- See https://trac.osgeo.org/postgis/ticket/5709
+SELECT NULL FROM createtopology('t5709');
+SELECT 't5709', 'edge', * FROM TopoGeo_addLineString('t5709',
+  'LINESTRING(
+    0 0,
+    5 65.2,
+    10 0,
+    0 0)
+SELECT 't5709', 'mbr-invalid-before', face_id
+FROM t5709.face
+WHERE face_id > 0
+AND NOT ST_Equals(
+    mbr,
+    ST_Envelope(
+      ST_GetFaceGeometry('t5709', face_id)
+--set client_min_messages to DEBUG;
+SELECT NULL FROM ST_ChangeEdgeGeom('t5709', 1,
+  'LINESTRING(
+    0 0,
+    5 65.2000000000001,
+    10 0,
+    0 0)
+SELECT 't5709', 'mbr-invalid-after', face_id
+FROM t5709.face
+WHERE face_id > 0
+AND NOT ST_Equals(
+    mbr,
+    ST_Envelope(
+SELECT NULL FROM topology.DropTopology('t5709');
diff --git a/topology/test/regress/st_changeedgegeom_expected b/topology/test/regress/st_changeedgegeom_expected
index 9e29700c7..f2bc4fb95 100644
--- a/topology/test/regress/st_changeedgegeom_expected
+++ b/topology/test/regress/st_changeedgegeom_expected
@@ -36,3 +36,4 @@ T13.2|Edge 29 changed
 T13.3|26
 ERROR:  Edge motion collision at POINT(-1.1697 47.7825)
 Topology 'city_data' dropped
+t5709|edge|1
Summary of changes:
 liblwgeom/topo/lwgeom_topo.c                     |  8 ++++--
 topology/test/regress/st_changeedgegeom.sql      | 36 ++++++++++++++++++++++++
 topology/test/regress/st_changeedgegeom_expected |  1 +
 3 files changed, 43 insertions(+), 2 deletions(-)
hooks/post-receive
