[PostGIS] #5712: TopoGeo_LoadGeometry coredumps database when NULL geometry
PostGIS trac at osgeo.org
Mon Apr 15 02:00:57 PDT 2024
 Reporter:  Lars Aksel Opsahl  |      Owner:  strk
     Type:  defect             |     Status:  new
 Priority:  medium             |  Milestone:  PostGIS 3.4.3
Component:  topology           |    Version:  3.4.x
 Keywords:                     |
 On
 POSTGIS="3.5.0dev 3.4.0rc1-1087-g2e4d96393" [EXTENSION] PGSQL="140"
 GEOS="3.12.1-CAPI-1.18.1" PROJ="9.4.0 NETWORK_ENABLED=OFF
 URL_ENDPOINT=https://cdn.proj.org
 USER_WRITABLE_DIRECTORY=/Users/lop/Library/Application Support/proj
 DATABASE_PATH=/opt/homebrew/Cellar/proj/9.4.0/share/proj/proj.db"
 LIBXML="2.13.0" LIBJSON="0.17" TOPOLOGY
 PostgreSQL 14.11 (Homebrew) on aarch64-apple-darwin23.2.0, compiled by
 Apple clang version 15.0.0 (clang-1500.1.0.2.5), 64-bit
 Running this command
 SELECT topology.CreateTopology ('t1', 4258 , 0);
  createtopology
               3
 (1 row)
 select topology.TopoGeo_LoadGeometry('t1',null::geometry,0::float8);
 I get this response
 server closed the connection unexpectedly
         This probably means the server terminated abnormally
         before or while processing the request.
 The connection to the server was lost. Attempting reset: Failed.
 And the log I find this
 2024-04-15 10:56:13.390 CEST [35641] LOG:  server process (PID 35927) was
 terminated by signal 11: Segmentation fault: 11
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5712>
