[SCM] PostGIS branch master updated. 3.4.0rc1-1088-g1d12c312b
Mon Apr 15 02:26:55 PDT 2024
the project "PostGIS".
       via  1d12c312bdb2b7d900a01d0259b1f1259edf211d (commit)
      from  2e4d963934d03875674d9f1e7c41e45432c3ffae (commit)
revisions in full, below.
commit 1d12c312bdb2b7d900a01d0259b1f1259edf211d
Author: Sandro Santilli <strk at kbt.io>
Date:   Mon Apr 15 11:26:14 2024 +0200
    Fix crash on NULL geometry input to LoadGeometry
    Also short-circuit the EMPTY case
    Includes regress test.
    Closes #5712
diff --git a/topology/postgis_topology.c b/topology/postgis_topology.c
index 1ba5dea36..b6c5ea8ac 100644
--- a/topology/postgis_topology.c
+++ b/topology/postgis_topology.c
@@ -5627,12 +5627,17 @@ Datum TopoGeo_LoadGeometry(PG_FUNCTION_ARGS)
   LWGEOM *lwgeom;
   LWT_TOPOLOGY *topo;
+  if ( PG_ARGISNULL(0) || PG_ARGISNULL(1) )
+    lwpgerror("SQL/MM Spatial exception - null argument");
+    PG_RETURN_NULL();
   toponame_text = PG_GETARG_TEXT_P(0);
   toponame = text_to_cstring(toponame_text);
   PG_FREE_IF_COPY(toponame_text, 0);
   geom = PG_GETARG_GSERIALIZED_P(1);
-  lwgeom = lwgeom_from_gserialized(geom);
   tol = PG_GETARG_FLOAT8(2);
   if ( tol < 0 )
@@ -5657,10 +5662,16 @@ Datum TopoGeo_LoadGeometry(PG_FUNCTION_ARGS)
     PG_RETURN_NULL();
-  POSTGIS_DEBUG(1, "Calling lwt_LoadGeometry");
-  lwt_LoadGeometry(topo, lwgeom, tol);
-  POSTGIS_DEBUG(1, "lwt_LoadGeometry returned");
-  lwgeom_free(lwgeom);
+  /* Nothing to do if the input is empty */
+  if (gserialized_is_empty(geom) != LW_TRUE)
+    lwgeom = lwgeom_from_gserialized(geom);
+    POSTGIS_DEBUG(1, "Calling lwt_LoadGeometry");
+    lwt_LoadGeometry(topo, lwgeom, tol);
+    POSTGIS_DEBUG(1, "lwt_LoadGeometry returned");
+    lwgeom_free(lwgeom);
   PG_FREE_IF_COPY(geom, 1);
   lwt_FreeTopology(topo);
diff --git a/topology/test/regress/topogeo_loadgeometry.sql b/topology/test/regress/topogeo_loadgeometry.sql
index dbb3db8d6..ce434305b 100644
--- a/topology/test/regress/topogeo_loadgeometry.sql
+++ b/topology/test/regress/topogeo_loadgeometry.sql
@@ -1,4 +1,8 @@
 SET client_min_messages TO WARNING;
+-- Unexisted topology call
+SELECT 'unexistent_topo', topology.TopoGeo_LoadGeometry('t', 'POINT(0 0)'::geometry);
 SELECT NULL FROM topology.CreateTopology('t');
 CREATE FUNCTION t.print_counts(lbl text) RETURNS TEXT
@@ -11,6 +15,12 @@ AS $$
 $$ LANGUAGE 'sql';
+-- Null call
+SELECT 'null', topology.TopoGeo_LoadGeometry('t', NULL::geometry);
+-- Empty
+SELECT 'empty', topology.TopoGeo_LoadGeometry('t', 'POINT EMPTY'::geometry);
 --            o
diff --git a/topology/test/regress/topogeo_loadgeometry_expected b/topology/test/regress/topogeo_loadgeometry_expected
index 1467fa7f6..2063bf22e 100644
--- a/topology/test/regress/topogeo_loadgeometry_expected
+++ b/topology/test/regress/topogeo_loadgeometry_expected
@@ -1,3 +1,6 @@
+ERROR:  SQL/MM Spatial exception - invalid topology name
+ERROR:  SQL/MM Spatial exception - null argument
+empty|
 point1|1 nodes|0 edges|0 faces
 mpoint1|2 nodes|0 edges|0 faces
 mline1|6 nodes|4 edges|0 faces
Summary of changes:
 topology/postgis_topology.c                         | 21 ++++++++++++++++-----
 topology/test/regress/topogeo_loadgeometry.sql      | 10 ++++++++++
 topology/test/regress/topogeo_loadgeometry_expected |  3 +++
 3 files changed, 29 insertions(+), 5 deletions(-)
hooks/post-receive
