[PostGIS] #5713: GEOS3.12 - "TopologyException: side location conflict" on valid input geometries
PostGIS trac at osgeo.org
Wed Apr 17 14:23:20 PDT 2024
geometries
 Reporter:  dannytoone  |      Owner:  pramsey
     Type:  defect      |     Status:  new
 Priority:  medium      |  Milestone:  PostGIS 3.4.3
Component:  postgis     |    Version:  3.4.x
 Keywords:              |
 This is from a recent version of PostGIS running on AWS RDS:
 POSTGIS="3.4.0 0874ea3" [EXTENSION] PGSQL="160" GEOS="3.12.0-CAPI-1.18.0"
 PROJ="8.0.1 NETWORK_ENABLED=OFF URL_ENDPOINT=https://cdn.proj.org
 USER_WRITABLE_DIRECTORY=/tmp/proj
 DATABASE_PATH=/rdsdbbin/postgres-16.1.R1/share/proj/proj.db" GDAL="GDAL
 3.4.3, released 2022/04/22" LIBXML="2.9.1" LIBJSON="0.15"
 LIBPROTOBUF="1.3.2" WAGYU="0.5.0 (Internal)" RASTER
 ST_Equals as well as ST_Touches fail on these input geometries. I will
 attach a csv output containing two geometry columns which fail.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5713>
