[PostGIS] #5715: A new flag --without-comments
PostGIS trac at osgeo.org
Thu Apr 18 03:45:05 PDT 2024
 Reporter:  Lars Aksel Opsahl  |      Owner:  pramsey
     Type:  enhancement        |     Status:  new
 Priority:  low                |  Milestone:  PostGIS 3.4.3
Component:  postgis            |    Version:  3.4.x
 Keywords:                     |
 Right now I have problem with building doc my local mac which fails this
 error
 grep -v '&postgis_special;' postgis.xml > postgis-nospecial.xml.in
 /usr/local/bin/xmllint --path
 .:/Users/lop/dev/pg_build_from_source/postgis/doc --noent -o postgis-
 nospecial.xml postgis-nospecial.xml.in dyld[56362]: Symbol not found:
 _xmlCtxtSetMaxAmplification Referenced from: <67ABBA84-EFD3-3806-86AE-
 9975D0EC3811> /usr/local/bin/xmllint Expected in: <236C8BF2-0800-396C-
 AF03-B5328CAD1FD6> /usr/lib/libxml2.2.dylib make[1]: *** [postgis-
 nospecial.xml] Abort trap: 6 make: *** [all] Error 1
 But when testing this now I do not need the doc so @strk told that could
 set CAN_BUILD_COMMENTS to empty to avoid build comments/doc.
 But maybe we could have a flag to be used like this
 ./configure  --without-comments
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5715>
