[PostGIS] #5713: GEOS3.12 - "TopologyException: side location conflict" on valid input geometries
PostGIS trac at osgeo.org
Thu Apr 18 15:59:58 PDT 2024
geometries
  Reporter:  dannytoone  |      Owner:  pramsey
      Type:  defect      |     Status:  closed
  Priority:  medium      |  Milestone:  PostGIS 3.4.3
 Component:  postgis     |    Version:  3.4.x
Resolution:  wontfix     |   Keywords:
Changes (by pramsey):
 * status:  new => closed
 * resolution:   => wontfix
Old description:
> This is from a recent version of PostGIS running on AWS RDS:
> POSTGIS="3.4.0 0874ea3" [EXTENSION] PGSQL="160" GEOS="3.12.0-CAPI-1.18.0"
> PROJ="8.0.1 NETWORK_ENABLED=OFF URL_ENDPOINT=https://cdn.proj.org
> USER_WRITABLE_DIRECTORY=/tmp/proj
> DATABASE_PATH=/rdsdbbin/postgres-16.1.R1/share/proj/proj.db" GDAL="GDAL
> 3.4.3, released 2022/04/22" LIBXML="2.9.1" LIBJSON="0.15"
> LIBPROTOBUF="1.3.2" WAGYU="0.5.0 (Internal)" RASTER
> ST_Equals as well as ST_Touches fail on these input geometries. I will
> attach a csv output containing two geometry columns which fail.
New description:
Comment:
 Confirmed. Since the Relate code is likely to be removed and replaced from
 GEOS in the next cycle, this particular issue will likely not be fixed. A
 work around it to apply a very small precision reduction, which should
 shake out the very small nearly parallel lines in your original that are
 causing the problem.
 select st_equals(ST_ReducePrecision(mark_geom,0.00000001),
 st_reduceprecision(fips_geom, 0.00000001)) from g5713
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5713#comment:1>
