[PostGIS] #5718: `st_isvalid(point(NaN, NaN))` is true
PostGIS trac at osgeo.org
Wed Apr 24 20:55:08 PDT 2024
  Reporter:  n0099    |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:
 Component:  postgis  |    Version:  3.4.x
Resolution:           |   Keywords:
Comment (by mdavis):
 The [https://www.geopackage.org/spec/ GeoPackage spec] also specifies the
 same approach:
 > If the geometry is a Point, it SHALL be encoded with each coordinate
 value set to an IEEE-754 quiet NaN value. GeoPackages SHALL use big endian
 0x7ff8000000000000 or little endian 0x000000000000f87f as the binary
 encoding of the NaN values. (This is because Well-Known Binary as defined
 in OGC 06-103r4 [I9] does not provide a standardized encoding for an empty
 point set, i.e., 'Point Empty' in Well-Known Text.)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5718#comment:5>
