[PostGIS] #5720: shp2pgsql no longer renaming system column names xmin, xmax
PostGIS trac at osgeo.org
Fri Apr 26 07:07:11 PDT 2024
  Reporter:  turntwo463       |      Owner:  robe
      Type:  defect           |     Status:  new
  Priority:  high             |  Milestone:  PostGIS 3.4.3
 Component:  utils/shp2pgsql  |    Version:  3.4.x
Resolution:                   |   Keywords:  xmin,xmax
Changes (by turntwo463):
 * Attachment "small_example.7z" added.
 Zip of sample shapefile to exhibit issue
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5720>
