[SCM] PostGIS branch stable-3.4 updated. 3.4.2-36-g9a95da62c
Mon Apr 29 09:42:51 PDT 2024
the project "PostGIS".
The branch, stable-3.4 has been updated
       via  9a95da62c43f6b132edbac52bae0ec5f988d2ea1 (commit)
      from  1f5caafe8ad97f55372c2f56ef7745fcd5c8ee9c (commit)
revisions in full, below.
commit 9a95da62c43f6b132edbac52bae0ec5f988d2ea1
Author: Sandro Santilli <strk at kbt.io>
Date:   Mon Apr 29 17:03:44 2024 +0200
    Compute tolerance by edge, when adding intersection points
    Increases noding robustness.
    References ticket #5722 in 3.4 branch (3.4.3dev)
    Includes regression test
diff --git a/NEWS b/NEWS
index 87d6d8947..b20968c76 100644
--- a/NEWS
+++ b/NEWS
@@ -7,6 +7,7 @@ To take advantage of all SFCGAL featurs, SFCGAL 1.4.1+ is needed.
 * Bug Fixes *
+ - #5722, Improve robustness of adding lines to topology (Sandro Santilli)
  - #5709, Fix loose mbr in topology.face on ST_ChangeEdgeGeom (Sandro Santilli)
  - #5698, Fix robustness issue splitting line by vertex very close to endpoints,
           affecting topology population functions (Sandro Santilli)
@@ -26,7 +27,7 @@ To take advantage of all SFCGAL featurs, SFCGAL 1.4.1+ is needed.
            Fix for PG17 security change (Regina Obe)
  - #5695, [address_standardizer_data_us] standardize_address
           incorrect handling of directionals (Regina Obe)
- - #5653, Do not simplify away points when linestring doubles back on
+ - #5653, Do not simplify away points when linestring doubles back on
           itself (Paul Ramsey)
 PostGIS 3.4.2
diff --git a/liblwgeom/lwgeom_topo.c b/liblwgeom/lwgeom_topo.c
index 317eabfe6..303624ed1 100644
--- a/liblwgeom/lwgeom_topo.c
+++ b/liblwgeom/lwgeom_topo.c
@@ -5448,7 +5448,7 @@ _lwt_AddLineEdge( LWT_TOPOLOGY* topo, LWLINE* edge, double tol,
     return 0; /* must be empty */
   nid[0] = _lwt_AddPoint( topo, start_point,
-                          _lwt_minTolerance(lwpoint_as_lwgeom(start_point)),
+                          tol,
                           handleFaceSplit, &mm );
   lwpoint_free(start_point); /* too late if lwt_AddPoint calls lwerror */
   if ( nid[0] == -1 ) return -1; /* lwerror should have been called */
@@ -5463,7 +5463,7 @@ _lwt_AddLineEdge( LWT_TOPOLOGY* topo, LWLINE* edge, double tol,
     return -1;
   nid[1] = _lwt_AddPoint( topo, end_point,
-                          _lwt_minTolerance(lwpoint_as_lwgeom(end_point)),
+                          tol,
   moved += mm;
   lwpoint_free(end_point); /* too late if lwt_AddPoint calls lwerror */
@@ -5977,7 +5977,13 @@ _lwt_AddLine(LWT_TOPOLOGY* topo, LWLINE* line, double tol, int* nedges,
 #endif
-    id = _lwt_AddLineEdge( topo, lwgeom_as_lwline(g), tol, handleFaceSplit, &forward );
+    id = _lwt_AddLineEdge(
+      topo,
+      lwgeom_as_lwline(g),
+      _lwt_minTolerance(g), /* TODO: compute actual drift introduced by GEOS ? */
+      handleFaceSplit,
+      &forward
     LWDEBUGF(1, "_lwt_AddLineEdge returned %" LWTFMT_ELEMID, id);
     if ( id < 0 )
diff --git a/topology/test/regress/topogeo_addlinestring_robust.sql b/topology/test/regress/topogeo_addlinestring_robust.sql
new file mode 100644
index 000000000..27d30a196
--- /dev/null
+++ b/topology/test/regress/topogeo_addlinestring_robust.sql
@@ -0,0 +1,178 @@
+CREATE FUNCTION runTest( lbl text, lines geometry[], newline geometry, prec float8, debug bool default false )
+RETURNS SETOF text AS
+$BODY$
+DECLARE
+  g geometry;
+  n int := 0;
+  rec record;
+BEGIN
+  IF EXISTS ( SELECT * FROM topology.topology WHERE name = 'topo' )
+  THEN
+    PERFORM topology.DropTopology ('topo');
+  END IF;
+  PERFORM topology.CreateTopology ('topo');
+  CREATE TABLE topo.fl(lbl text, g geometry);
+  PERFORM topology.AddTopoGeometryColumn('topo','topo','fl','tg','LINESTRING');
+  CREATE TABLE topo.fa(lbl text, g geometry);
+  PERFORM topology.AddTopoGeometryColumn('topo','topo','fa','tg','POLYGON');
+  -- Add a polygon containing all lines
+  PERFORM topology.TopoGeo_addPolygon('topo', ST_Expand(ST_Extent(geom), 100))
+  FROM unnest(lines) geom;
+  -- Add all lines
+  FOR g IN SELECT unnest(lines)
+  LOOP
+    INSERT INTO topo.fl(lbl, tg) VALUES
+      ( 'l'||n, topology.toTopoGeom(g, 'topo', 1) );
+    n = n+1;
+  END LOOP;
+  FOR n IN SELECT face_id FROM topo.face WHERE face_id > 0
+  LOOP
+    INSERT INTO topo.fa(lbl, tg) VALUES
+      ( 'a'||n, topology.CreateTopoGeom('topo', 3, 2, ARRAY[ARRAY[n,3]]) );
+    n = n+1;
+  END LOOP;
+  UPDATE topo.fl SET g = tg::geometry;
+  UPDATE topo.fa SET g = tg::geometry;
+  RETURN QUERY SELECT  array_to_string(ARRAY[
+    lbl,
+    '-checking-'
+  IF debug THEN
+      lbl, -- 'topo',
+      'bfr',
+      'E' || edge_id,
+      'next_left:'||next_left_edge,
+      'next_right:'||next_right_edge,
+      'face_left:'||left_face,
+      'face_right:'||right_face
+    FROM topo.edge
+    ORDER BY edge_id;
+  END IF;
+  IF debug THEN
+    set client_min_messages to DEBUG;
+  END IF;
+  BEGIN
+    PERFORM topology.TopoGeo_addLinestring('topo', newline, prec);
+  EXCEPTION WHEN OTHERS THEN
+    RETURN QUERY SELECT format('%s|addline exception|%s (%s)', lbl, SQLERRM, SQLSTATE);
+  END;
+  IF debug THEN
+    set client_min_messages to WARNING;
+  END IF;
+  IF debug THEN
+      lbl, --'topo',
+      'aft',
+      'E' || edge_id,
+    FROM topo.edge
+    ORDER BY edge_id;
+  END IF;
+  RETURN QUERY
+    WITH j AS (
+      SELECT
+        row_number() over () as rn,
+        to_json(s) as o
+      FROM ValidateTopology('topo') s
+    SELECT
+      array_to_string(
+        ARRAY[lbl,'unexpected','validity issue'] ||
+        array_agg(x.value order by x.ordinality),
+    FROM j, json_each_text(j.o)
+    WITH ordinality AS x
+    GROUP by j.rn;
+    lbl,
+    'unexpected',
+    'lineal drift',
+    l,
+    dist::text
+  FROM (
+    SELECT t.lbl l, ST_HausdorffDistance(t.g, tg::geometry) dist
+    FROM topo.fl t
+  ) foo WHERE dist >= COALESCE(
+      NULLIF(prec,0),
+      topology._st_mintolerance(newline)
+  ORDER BY foo.l;
+  SELECT sum(ST_Area(t.g)) as before, sum(ST_Area(tg::geometry)) as after
+  FROM topo.fa t
+  INTO rec;
+  IF rec.before != rec.after THEN
+      lbl,
+      'unexpected total area change',
+      rec.before::text,
+      rec.after::text
+      lbl,
+      'area change',
+      l,
+      rec.bfr::text,
+      rec.aft::text
+    FROM (
+      SELECT t.lbl l, ST_Area(t.g) bfr, ST_Area(tg::geometry) aft
+      FROM topo.fa t
+    ) foo WHERE bfr != aft
+    ORDER BY foo.l;
+  END IF;
+  IF NOT debug THEN
+  END IF;
+END;
+$BODY$
+LANGUAGE 'plpgsql';
+SET client_min_messages to WARNING;
+-- See https://trac.osgeo.org/postgis/ticket/5722
+SELECT * FROM runTest('#5722',
+  ARRAY[
+  'LINESTRING(
+  -11.968112622212203 0.651457829865329,
+    8.13909499443551  0.334122751124234,
+  -11.964143711257549 0.31568377154268)'
+  'LINESTRING(
+  -0.65145782986533 -11.968112622212203,
+  -0.159231454672685  8.13973141470126)',
+  0
+) WHERE true ;
+DROP FUNCTION runTest(text, geometry[], geometry, float8, bool);
diff --git a/topology/test/regress/topogeo_addlinestring_robust_expected b/topology/test/regress/topogeo_addlinestring_robust_expected
index 000000000..2e4e863b5
--- /dev/null
+++ b/topology/test/regress/topogeo_addlinestring_robust_expected
@@ -0,0 +1 @@
+#5722|-checking-
diff --git a/topology/test/tests.mk b/topology/test/tests.mk
index 5c3f0e92e..f1cd062e3 100644
--- a/topology/test/tests.mk
+++ b/topology/test/tests.mk
@@ -73,6 +73,7 @@ TESTS += \
 	$(top_srcdir)/topology/test/regress/topoelementarray_agg.sql \
 	$(top_srcdir)/topology/test/regress/topoelement.sql \
 	$(top_srcdir)/topology/test/regress/topogeo_addlinestring.sql \
+	$(top_srcdir)/topology/test/regress/topogeo_addlinestring_robust.sql \
 	$(top_srcdir)/topology/test/regress/topogeo_addpoint.sql \
 	$(top_srcdir)/topology/test/regress/topogeo_addpolygon.sql \
 	$(top_srcdir)/topology/test/regress/topogeom_addtopogeom.sql \
Summary of changes:
 NEWS                                               |   3 +-
 liblwgeom/lwgeom_topo.c                            |  12 +-
 .../test/regress/topogeo_addlinestring_robust.sql  | 178 +++++++++++++++++++++
 .../regress/topogeo_addlinestring_robust_expected  |   1 +
 topology/test/tests.mk                             |   1 +
 5 files changed, 191 insertions(+), 4 deletions(-)
 create mode 100644 topology/test/regress/topogeo_addlinestring_robust.sql
 create mode 100644 topology/test/regress/topogeo_addlinestring_robust_expected
hooks/post-receive
