[SCM] PostGIS branch master updated. 3.4.0rc1-1100-g76971af97
Mon Apr 29 13:14:12 PDT 2024
the project "PostGIS".
       via  76971af97fd2ec757d4ac83a4bde40b79789eb6b (commit)
      from  a1d87944045dcca9b26ccaeca176d69799fce7e3 (commit)
revisions in full, below.
commit 76971af97fd2ec757d4ac83a4bde40b79789eb6b
Author: Sandro Santilli <strk at kbt.io>
Date:   Mon Apr 29 22:13:55 2024 +0200
    Revert "Compute tolerance by edge, when adding intersection points"
    This reverts commit a1d87944045dcca9b26ccaeca176d69799fce7e3.
diff --git a/liblwgeom/topo/lwgeom_topo.c b/liblwgeom/topo/lwgeom_topo.c
index 3db9a0819..570f449a5 100644
--- a/liblwgeom/topo/lwgeom_topo.c
+++ b/liblwgeom/topo/lwgeom_topo.c
@@ -5440,7 +5440,7 @@ _lwt_AddLineEdge( LWT_TOPOLOGY* topo, LWLINE* edge, double tol,
     return 0; /* must be empty */
   nid[0] = _lwt_AddPoint( topo, start_point,
-                          tol,
+                          _lwt_minTolerance(lwpoint_as_lwgeom(start_point)),
                           handleFaceSplit, &mm );
   lwpoint_free(start_point); /* too late if lwt_AddPoint calls lwerror */
   if ( nid[0] == -1 ) return -1; /* lwerror should have been called */
@@ -5456,7 +5456,7 @@ _lwt_AddLineEdge( LWT_TOPOLOGY* topo, LWLINE* edge, double tol,
     return -1;
   nid[1] = _lwt_AddPoint( topo, end_point,
-                          tol,
+                          _lwt_minTolerance(lwpoint_as_lwgeom(end_point)),
   lwpoint_free(end_point); /* too late if lwt_AddPoint calls lwerror */
   if ( nid[1] == -1 ) return -1; /* lwerror should have been called */
@@ -5989,13 +5989,7 @@ _lwt_AddLine(LWT_TOPOLOGY* topo, LWLINE* line, double tol, int* nedges,
 #endif
-    id = _lwt_AddLineEdge(
-      topo,
-      lwgeom_as_lwline(g),
-      _lwt_minTolerance(g), /* TODO: compute actual drift introduced by GEOS ? */
-      handleFaceSplit,
-      &forward
+    id = _lwt_AddLineEdge( topo, lwgeom_as_lwline(g), tol, handleFaceSplit, &forward );
     LWDEBUGF(1, "_lwt_AddLineEdge returned %" LWTFMT_ELEMID, id);
     if ( id < 0 )
diff --git a/topology/test/regress/topogeo_addlinestring_robust.sql b/topology/test/regress/topogeo_addlinestring_robust.sql
deleted file mode 100644
index 27d30a196..000000000
--- a/topology/test/regress/topogeo_addlinestring_robust.sql
+++ /dev/null
@@ -1,178 +0,0 @@
-CREATE FUNCTION runTest( lbl text, lines geometry[], newline geometry, prec float8, debug bool default false )
-RETURNS SETOF text AS
-$BODY$
-DECLARE
-  g geometry;
-  n int := 0;
-  rec record;
-BEGIN
-  IF EXISTS ( SELECT * FROM topology.topology WHERE name = 'topo' )
-  THEN
-    PERFORM topology.DropTopology ('topo');
-  END IF;
-  PERFORM topology.CreateTopology ('topo');
-  CREATE TABLE topo.fl(lbl text, g geometry);
-  PERFORM topology.AddTopoGeometryColumn('topo','topo','fl','tg','LINESTRING');
-  CREATE TABLE topo.fa(lbl text, g geometry);
-  PERFORM topology.AddTopoGeometryColumn('topo','topo','fa','tg','POLYGON');
-  -- Add a polygon containing all lines
-  PERFORM topology.TopoGeo_addPolygon('topo', ST_Expand(ST_Extent(geom), 100))
-  FROM unnest(lines) geom;
-  -- Add all lines
-  FOR g IN SELECT unnest(lines)
-  LOOP
-    INSERT INTO topo.fl(lbl, tg) VALUES
-      ( 'l'||n, topology.toTopoGeom(g, 'topo', 1) );
-    n = n+1;
-  END LOOP;
-  FOR n IN SELECT face_id FROM topo.face WHERE face_id > 0
-  LOOP
-    INSERT INTO topo.fa(lbl, tg) VALUES
-      ( 'a'||n, topology.CreateTopoGeom('topo', 3, 2, ARRAY[ARRAY[n,3]]) );
-    n = n+1;
-  END LOOP;
-  UPDATE topo.fl SET g = tg::geometry;
-  UPDATE topo.fa SET g = tg::geometry;
-  RETURN QUERY SELECT  array_to_string(ARRAY[
-    lbl,
-    '-checking-'
-  IF debug THEN
-      lbl, -- 'topo',
-      'bfr',
-      'E' || edge_id,
-      'next_left:'||next_left_edge,
-      'next_right:'||next_right_edge,
-      'face_left:'||left_face,
-      'face_right:'||right_face
-    FROM topo.edge
-    ORDER BY edge_id;
-  END IF;
-  IF debug THEN
-    set client_min_messages to DEBUG;
-  END IF;
-  BEGIN
-    PERFORM topology.TopoGeo_addLinestring('topo', newline, prec);
-  EXCEPTION WHEN OTHERS THEN
-    RETURN QUERY SELECT format('%s|addline exception|%s (%s)', lbl, SQLERRM, SQLSTATE);
-  END;
-  IF debug THEN
-    set client_min_messages to WARNING;
-  END IF;
-  IF debug THEN
-      lbl, --'topo',
-      'aft',
-      'E' || edge_id,
-    FROM topo.edge
-    ORDER BY edge_id;
-  END IF;
-  RETURN QUERY
-    WITH j AS (
-      SELECT
-        row_number() over () as rn,
-        to_json(s) as o
-      FROM ValidateTopology('topo') s
-    SELECT
-      array_to_string(
-        ARRAY[lbl,'unexpected','validity issue'] ||
-        array_agg(x.value order by x.ordinality),
-    FROM j, json_each_text(j.o)
-    WITH ordinality AS x
-    GROUP by j.rn;
-    lbl,
-    'unexpected',
-    'lineal drift',
-    l,
-    dist::text
-  FROM (
-    SELECT t.lbl l, ST_HausdorffDistance(t.g, tg::geometry) dist
-    FROM topo.fl t
-  ) foo WHERE dist >= COALESCE(
-      NULLIF(prec,0),
-      topology._st_mintolerance(newline)
-  ORDER BY foo.l;
-  SELECT sum(ST_Area(t.g)) as before, sum(ST_Area(tg::geometry)) as after
-  FROM topo.fa t
-  INTO rec;
-  IF rec.before != rec.after THEN
-      lbl,
-      'unexpected total area change',
-      rec.before::text,
-      rec.after::text
-      lbl,
-      'area change',
-      l,
-      rec.bfr::text,
-      rec.aft::text
-    FROM (
-      SELECT t.lbl l, ST_Area(t.g) bfr, ST_Area(tg::geometry) aft
-      FROM topo.fa t
-    ) foo WHERE bfr != aft
-    ORDER BY foo.l;
-  END IF;
-  IF NOT debug THEN
-  END IF;
-END;
-$BODY$
-LANGUAGE 'plpgsql';
-SET client_min_messages to WARNING;
--- See https://trac.osgeo.org/postgis/ticket/5722
-SELECT * FROM runTest('#5722',
-  ARRAY[
-  'LINESTRING(
-  -11.968112622212203 0.651457829865329,
-    8.13909499443551  0.334122751124234,
-  -11.964143711257549 0.31568377154268)'
-  'LINESTRING(
-  -0.65145782986533 -11.968112622212203,
-  -0.159231454672685  8.13973141470126)',
-  0
-) WHERE true ;
-DROP FUNCTION runTest(text, geometry[], geometry, float8, bool);
diff --git a/topology/test/regress/topogeo_addlinestring_robust_expected b/topology/test/regress/topogeo_addlinestring_robust_expected
index 2e4e863b5..000000000
--- a/topology/test/regress/topogeo_addlinestring_robust_expected
+++ /dev/null
@@ -1 +0,0 @@
-#5722|-checking-
diff --git a/topology/test/tests.mk b/topology/test/tests.mk
index 528c79238..02edc26fc 100644
--- a/topology/test/tests.mk
+++ b/topology/test/tests.mk
@@ -73,7 +73,6 @@ TESTS += \
 	$(top_srcdir)/topology/test/regress/topoelementarray_agg.sql \
 	$(top_srcdir)/topology/test/regress/topoelement.sql \
 	$(top_srcdir)/topology/test/regress/topogeo_addlinestring.sql \
-	$(top_srcdir)/topology/test/regress/topogeo_addlinestring_robust.sql \
 	$(top_srcdir)/topology/test/regress/topogeo_addpoint.sql \
 	$(top_srcdir)/topology/test/regress/topogeo_addpolygon.sql \
 	$(top_srcdir)/topology/test/regress/topogeo_loadgeometry.sql \
Summary of changes:
 liblwgeom/topo/lwgeom_topo.c                       |  12 +-
 .../test/regress/topogeo_addlinestring_robust.sql  | 178 ---------------------
 .../regress/topogeo_addlinestring_robust_expected  |   1 -
 topology/test/tests.mk                             |   1 -
 4 files changed, 3 insertions(+), 189 deletions(-)
 delete mode 100644 topology/test/regress/topogeo_addlinestring_robust.sql
 delete mode 100644 topology/test/regress/topogeo_addlinestring_robust_expected
hooks/post-receive
