[PostGIS] #5711: Failed adding single touches interior of edge 128 LOCATION: pg_error, lwgeom_pg.c:361
PostGIS trac at osgeo.org
Mon Apr 29 22:47:40 PDT 2024
lwgeom_pg.c:361
  Reporter:  Lars Aksel Opsahl  |      Owner:  strk
      Type:  defect             |     Status:  new
  Priority:  medium             |  Milestone:  PostGIS 3.4.3
 Component:  topology           |    Version:  3.4.x
Resolution:                     |   Keywords:
Comment (by Lars Aksel Opsahl):
 Replying to [comment:2 strk]:
 > Simplified version of the test:
 > SELECT topology.CreateTopology ('topo_t5711');
 > SELECT topology.TopoGeo_addLinestring('topo_t5711', 'LINESTRING(
 > 10.330696729253674 59.869691324470494,
 > 10.33083177446384 59.86967354547033
 > 10.33083177446384 59.86967354547033,
 > 10.330803297725453 59.86967729449583,
 > 10.330803407291219 59.86967760716573
 > 10.330803266175977 59.86967720446249,
 I this test supose to work on latest master 'POSTGIS="3.5.0dev
 3.4.0rc1-1105-ga7ef07329" [EXTENSION] PGSQL="140"
 GEOS="3.12.1-CAPI-1.18.1" PROJ="9.3.0 NETWORK_ENABLED=OFF
 URL_ENDPOINT=https://cdn.proj.org USER_WRITABLE_DIRECTORY=/tmp/proj
 DATABASE_PATH=/usr/local/share/proj/proj.db" LIBXML="2.9.13"
 LIBPROTOBUF="1.3.3" WAGYU="0.5.0 (Internal)" TOPOLOGY' ?
 I still get this error
 ERROR:  XX000: Spatial exception - geometry boundary touches interior of
 edge 1
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5711#comment:6>
