[PostGIS] #5725: Undocumented st_offsetcurve behaviour change between 3.2 and 3.3
PostGIS trac at osgeo.org
Tue Apr 30 16:00:15 PDT 2024
  Reporter:              |      Owner:  pramsey
  gbartonowenstl         |
      Type:  defect      |     Status:  new
  Priority:  medium      |  Milestone:  PostGIS 3.3.7
 Component:  postgis     |    Version:  3.3.x
Resolution:              |   Keywords:  offsetcurve, release notes,
                         |  st_offsetcurve, reversing
Description changed by gbartonowenstl:
Old description:
> I've read all the release notes and searched the internet generally for
> this but I cannot find anything.
> It appears that between 3.2 and 3.3, st_offsetcurve started reversing the
> curves when a negative offset was given (the documented behaviour), where
> as previously it did not.
> Reproduction SQL:
> select
> PostGIS_Version(),
> st_startpoint(geom),
> st_startpoint(st_offsetcurve(geom, -0.1)),
>  st_distance(st_startpoint(geom), st_startpoint(st_offsetcurve(geom,
> -0.1)))
> from
> (values (st_geomfromtext('LINESTRING (2302997.443737494
> 116854.4859950367, 2303083.234236186 117132.01622010056)',2163))) as vals
> (geom)
> One env:
> 3.3 USE_GEOS=1 USE_PROJ=1 USE_STATS=1   POINT (2302997.443737494
> 116854.4859950367)     POINT (2303083.3297756314 117131.98668682482)
> 290.48759954576633
> Older env:
> 3.2 USE_GEOS=1 USE_PROJ=1 USE_STATS=1   POINT (2302997.443737494
> 116854.4859950367)     POINT (2302997.5392769394 116854.45646176096)
> 0.10000000013339401
> I think this is due to a geos change: https://github.com/dr-
> jts/geos/commit/7561b50f943305b1419bd655e10e7dcad2cb9492
> I'd say this was mostly a bug in the documentation/release notes but I
> suspect it will cause subtle sadness for many
New description:
 Reproduction SQL:
 select
 PostGIS_Version(),
 -0.1)))
 from
 (values (st_geomfromtext('LINESTRING (2302997.443737494 116854.4859950367,
 2303083.234236186 117132.01622010056)',2163))) as vals (geom)
 One env:
 {{{3.3 USE_GEOS=1 USE_PROJ=1 USE_STATS=1        POINT (2302997.443737494
 290.48759954576633}}}
 Older env:
 {{{3.2 USE_GEOS=1 USE_PROJ=1 USE_STATS=1        POINT (2302997.443737494
 0.10000000013339401}}}
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5725#comment:1>
