[PostGIS] #5664: Yum Update nothing provides libarmadillo.so.12()(64bit) needed by gdal36-libs-3.6.4-6PGDG.rhel9.x86_64 from pgdg-common
PostGIS trac at osgeo.org
Tue Feb 6 11:04:01 PST 2024
  Reporter:  marc3932  |      Owner:  pramsey
      Type:  defect    |     Status:  new
  Priority:  medium    |  Milestone:  PostGIS 3.4.2
 Component:  postgis   |    Version:  3.4.x
Resolution:            |   Keywords:
Description changed by marc3932:
Old description:
> *PROBLEM*
> *yum update nothing provides libarmadillo.so.12()(64bit) needed by
> gdal36-libs-3.6.4-6PGDG.rhel9.x86_64 from pgdg-common  *
> [root at rhel9-pg14 ~]# yum update --exclude=postgis33_14
> --exclude=postgresql14*
> Updating Subscription Management repositories.
> EPEL_9
> 24 kB/s | 2.3 kB     00:00
> Red Hat Enterprise Linux 9 for x86_64 - AppStream (RPMs)
> 39 kB/s | 4.5 kB     00:00
> Red Hat CodeReady Linux Builder for RHEL 9 x86_64 (RPMs)
> 38 kB/s | 4.5 kB     00:00
> Red Hat Enterprise Linux 9 for x86_64 - BaseOS (RPMs)
> 37 kB/s | 4.1 kB     00:00
> Error:
>  Problem: cannot install the best update candidate for package
> gdal36-libs-3.6.4-5PGDG.rhel9.x86_64
>   - nothing provides libarmadillo.so.12()(64bit) needed by
> (try to add '--skip-broken' to skip uninstallable packages or '--nobest'
> to use not only best candidate packages)
> *NOTE:*  --skip-broken still returns the same error message, and --nobest
> just skips the gdal36-libs update
> *RHEL 9.3 DETAILS*
> [root(at)rhel9-pg14 ~]# cat /etc/redhat-release
> Red Hat Enterprise Linux release 9.3 (Plow)
> [root(at)rhel9-pg14 ~]# rpm -qa | grep postgres | sort
> postgresql14-14.10-1PGDG.rhel9.x86_64
> postgresql14-contrib-14.10-1PGDG.rhel9.x86_64
> postgresql14-libs-14.10-1PGDG.rhel9.x86_64
> postgresql14-server-14.10-1PGDG.rhel9.x86_64
> [root(at)rhel9-pg14 ~]# rpm -qa | grep postgis | sort
> postgis34_14-3.4.0-1PGDG.rhel9.x86_64
> [root at rhel9-pg14 ~]# rpm -qa | grep armadillo | sort
> armadillo-10.8.2-4.el9.x86_64
> [root at rhel9-pg14 ~]# rpm -qa | grep gdal | sort
> gdal35-libs-3.5.3-7PGDG.rhel9.x86_64
> [root(at)rhel9-pg14 ~]# subscription-manager repos --list-enabled
> Available Repositories in /etc/yum.repos.d/redhat.repo
> Repo ID:   rhel-9-for-x86_64-appstream-rpms
> Repo Name: Red Hat Enterprise Linux 9 for x86_64 - AppStream (RPMs)
> Repo URL:
> https://red-inf-
> cap-p01.esri.com/pulp/content/ESRI/LEP_Patch/cv_patch/content/dist/rhel9/$releasever/x86_64/appstream/os
> Enabled:   1
> Repo ID:   ESRI_EPEL_9_EPEL_9
> Repo Name: EPEL_9
> Repo URL:
> https://red-inf-
> cap-p01.esri.com/pulp/content/ESRI/LEP_Patch/cv_patch/custom/EPEL_9/EPEL_9
> Enabled:   1
> Repo ID:   rhel-9-for-x86_64-baseos-rpms
> Repo Name: Red Hat Enterprise Linux 9 for x86_64 - BaseOS (RPMs)
> Repo URL:
> https://red-inf-
> cap-p01.esri.com/pulp/content/ESRI/LEP_Patch/cv_patch/content/dist/rhel9/$releasever/x86_64/baseos/os
> Enabled:   1
> Repo ID:   codeready-builder-for-rhel-9-x86_64-rpms
> Repo Name: Red Hat CodeReady Linux Builder for RHEL 9 x86_64 (RPMs)
> Repo URL:
> https://red-inf-
> /codeready-builder/os
> Enabled:   1
> [root(at)rhel9-pg14 ~]# ls -la /etc/yum.repos.d/
> total 52
> drwxr-xr-x.   2 root root    85 Jan 31 16:13 .
> drwxr-xr-x. 136 root root  8192 Feb  2 10:33 ..
> -rw-r--r--.   1 root root 13067 Dec 25 15:11 pgdg-redhat-all.repo
> -rw-r--r--.   1 root root 14013 Oct 17 04:10 pgdg-redhat-all.repo.old
> -rw-r--r--.   1 root root  4657 Jan 31 16:09 redhat.repo
New description:
 *PROBLEM*
 EPEL_9
 Error:
 *RHEL 9.3 DETAILS*
 Repo URL:
 https://red-inf-
 Enabled:   1
 Repo Name: EPEL_9
 Repo URL:
 https://red-inf-
 Enabled:   1
 Repo URL:
 https://red-inf-
 Enabled:   1
 Repo URL:
 https://red-inf-
 Enabled:   1
 total 52
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5664#comment:1>
