[SCM] PostGIS branch stable-3.0 updated. 3.0.10-16-gdd7f67e7a
Tue Feb 6 14:25:40 PST 2024
the project "PostGIS".
The branch, stable-3.0 has been updated
       via  dd7f67e7a85103219cdbc49f62e18619bf2a33e6 (commit)
      from  299ac29df823ad904d627037bf95f8365c6a50cd (commit)
revisions in full, below.
commit dd7f67e7a85103219cdbc49f62e18619bf2a33e6
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Tue Feb 6 14:25:13 2024 -0800
    Bump version for 3.0.11 release
diff --git a/NEWS b/NEWS
index 6c1b49e21..640de8089 100644
--- a/NEWS
+++ b/NEWS
@@ -1,5 +1,5 @@
-PostGIS 3.0.11dev
-xxxx/xx/xx
+PostGIS 3.0.11
+2024/02/06
 * Bug Fixes *
@@ -13,7 +13,6 @@ xxxx/xx/xx
  - #5639, ST_DFullyWithin line/poly error case (Paul Ramsey)
  - #5662, Change XML parsers to SAX2 (Paul Ramsey)
 PostGIS 3.0.10
 2023/11/19
diff --git a/README.postgis b/README.postgis
index 8b743945f..311aef250 100644
--- a/README.postgis
+++ b/README.postgis
@@ -1,8 +1,8 @@
 PostGIS - Geographic Information Systems Extensions to PostgreSQL
-:Version: 3.0.10
-:Date: 2023-11-19
+:Version: 3.0.11
+:Date: 2024-02-06
 :Website: https://postgis.net
 This distribution contains a module which implements GIS simple features, ties
diff --git a/Version.config b/Version.config
index 4aae9f088..617f9f144 100644
--- a/Version.config
+++ b/Version.config
@@ -5,7 +5,7 @@
 POSTGIS_MAJOR_VERSION=3
 POSTGIS_MINOR_VERSION=0
-POSTGIS_MICRO_VERSION=11dev
+POSTGIS_MICRO_VERSION=11
 # Liblwgeom interface versioning, reset to 0:0:0 (cur:age:rev)
 # when changing POSTGIS_MINOR_VERSION
diff --git a/doc/release_notes.xml b/doc/release_notes.xml
index bb49c8cc4..0427718be 100644
--- a/doc/release_notes.xml
+++ b/doc/release_notes.xml
@@ -2,18 +2,34 @@
 <appendix id="release_notes">
   <title>Appendix</title>
     <subtitle>Release Notes</subtitle>
-      <sect1>
-        <title>Release 3.0.10</title>
-        <para>Release date: 2023/11/19</para>
-        <para>This is a bug and security release. This version requires PostgreSQL 9.5+-13 and GEOS >= 3.6+
-              Additional features and enhancements enabled if you are running Proj6+, PostgreSQL 12+, and GEOS 3.8</para>
-        <simplesect>
-          <title>Bug Fixes</title>
- <para><ulink url="https://trac.osgeo.org/postgis/ticket/"></ulink>5450, Fix macro expansion recursion on powerpc architectures.
-           (Bas Couwenberg)</para>
- <para><ulink url="https://trac.osgeo.org/postgis/ticket/"></ulink>5568, Improve robustness of topology face split handling (Sandro Santilli)</para>
- <para><ulink url="https://trac.osgeo.org/postgis/ticket/"></ulink>5616, Fix to find docbook on newer docbook installs (Regina Obe)</para>
-        </simplesect>
+    <sect1>
+      <title>Release 3.0.11</title>
+      <para>Release date: 2024/02/06</para>
+      <para>This is a bug and security release. This version requires PostgreSQL 9.5+-13 and GEOS >= 3.6+
+            Additional features and enhancements enabled if you are running Proj6+, PostgreSQL 12+, and GEOS 3.8</para>
+      <simplesect>
+        <title>Bug Fixes</title>
+        <para><ulink url="https://trac.osgeo.org/postgis/ticket/5610">5610</ulink>, Allow Nan and infinity again in ST_SetPoint (Regina Obe)</para>
+        <para><ulink url="https://trac.osgeo.org/postgis/ticket/5627">5627</ulink>, Handling of EMPTY components in PiP check (Paul Ramsey)</para>
+        <para><ulink url="https://trac.osgeo.org/postgis/ticket/5604">5604</ulink>, Handle distance between collections with empty elements (Paul Ramsey)</para>
+        <para><ulink url="https://trac.osgeo.org/postgis/ticket/5635">5635</ulink>, Handle NaN points in ST_Split (Regina Obe)</para>
+        <para><ulink url="https://trac.osgeo.org/postgis/ticket/5580">5580</ulink>, Handle empty collection components in 3d distance (Paul Ramsey)</para>
+        <para><ulink url="https://trac.osgeo.org/postgis/ticket/5639">5639</ulink>, ST_DFullyWithin line/poly error case (Paul Ramsey)</para>
+        <para><ulink url="https://trac.osgeo.org/postgis/ticket/5662">5662</ulink>, Change XML parsers to SAX2 (Paul Ramsey)</para>
+      </simplesect>
+    </sect1>
+    <sect1>
+      <title>Release 3.0.10</title>
+      <para>Release date: 2023/11/19</para>
+      <simplesect>
+        <para><ulink url="https://trac.osgeo.org/postgis/ticket/5450">5450</ulink>, Fix macro expansion recursion on powerpc architectures.
+                 (Bas Couwenberg)</para>
+        <para><ulink url="https://trac.osgeo.org/postgis/ticket/5568">5568</ulink>, Improve robustness of topology face split handling (Sandro Santilli)</para>
+        <para><ulink url="https://trac.osgeo.org/postgis/ticket/5616">5616</ulink>, Fix to find docbook on newer docbook installs (Regina Obe)</para>
+      </simplesect>
     </sect1>
     <sect1>
         <title>Release 3.0.9</title>
Summary of changes:
 NEWS                  |  5 ++---
 README.postgis        |  4 ++--
 Version.config        |  2 +-
 doc/release_notes.xml | 40 ++++++++++++++++++++++++++++------------
 4 files changed, 33 insertions(+), 18 deletions(-)
hooks/post-receive
