[SCM] PostGIS branch stable-3.2 updated. 3.2.6-22-g32dc0cc4c
Tue Feb 6 18:04:10 PST 2024
the project "PostGIS".
The branch, stable-3.2 has been updated
       via  32dc0cc4c6fc12da33248b50420d1ad8dba3f131 (commit)
      from  2adb8a3b00e1ab24c777e65e8120ad0f2aa74224 (commit)
revisions in full, below.
commit 32dc0cc4c6fc12da33248b50420d1ad8dba3f131
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Tue Feb 6 18:04:06 2024 -0800
    Prepare for 3.2.7 release
diff --git a/NEWS b/NEWS
index 991b52119..24fd82600 100644
--- a/NEWS
+++ b/NEWS
@@ -1,5 +1,5 @@
 PostGIS 3.2.7
-xxxx/xx/xx
+2024/02/06
 This version requires PostgreSQL 9.6-15, GEOS 3.6 or higher, and Proj 4.9+
 Additional features are enabled if you are running GEOS 3.9+
diff --git a/README.postgis b/README.postgis
index aa972d412..325e90023 100644
--- a/README.postgis
+++ b/README.postgis
@@ -1,8 +1,8 @@
 PostGIS - Geographic Information Systems Extensions to PostgreSQL
-:Version: 3.2.6
-:Date: 2023-11-19
+:Version: 3.2.7
+:Date: 2024-02-06
 :Website: https://postgis.net
 This distribution contains a module which implements GIS simple features, ties
diff --git a/Version.config b/Version.config
index 01bab46c1..60cf0129b 100644
--- a/Version.config
+++ b/Version.config
@@ -5,7 +5,7 @@
 POSTGIS_MAJOR_VERSION=3
 POSTGIS_MINOR_VERSION=2
-POSTGIS_MICRO_VERSION=7dev
+POSTGIS_MICRO_VERSION=7
 # Liblwgeom interface versioning, reset to 0:0:0 (cur:age:rev)
 # when changing POSTGIS_MINOR_VERSION
diff --git a/doc/release_notes.xml b/doc/release_notes.xml
index 0b54c1ea9..65c03eced 100644
--- a/doc/release_notes.xml
+++ b/doc/release_notes.xml
@@ -2,6 +2,23 @@
 <appendix id="release_notes">
   <title>Appendix</title>
    <subtitle>Release Notes</subtitle>
+    <sect1>
+      <title>PostGIS 3.2.7</title>
+      <para>2024/02/06</para>
+      <simplesect>
+        <title>Bug Fixes</title>
+        <para><ulink url="https://trac.osgeo.org/postgis/ticket/5610">5610</ulink>, Allow Nan and infinity again in ST_SetPoint (Regina Obe)</para>
+        <para><ulink url="https://trac.osgeo.org/postgis/ticket/5627">5627</ulink>, Handling of EMPTY components in PiP check (Paul Ramsey)</para>
+        <para><ulink url="https://trac.osgeo.org/postgis/ticket/5629">5629</ulink>, Handling EMPTY components in repeated point removal (Paul Ramsey)</para>
+        <para><ulink url="https://trac.osgeo.org/postgis/ticket/5604">5604</ulink>, Handle distance between collections with empty elements (Paul Ramsey)</para>
+        <para><ulink url="https://trac.osgeo.org/postgis/ticket/5635">5635</ulink>, Handle NaN points in ST_Split (Regina Obe)</para>
+        <para>Logic error in ST_Covers(geography) (Paul Ramsey)</para>
+        <para><ulink url="https://trac.osgeo.org/postgis/ticket/5646">5646</ulink>, Crash on collections with empty members (Paul Ramsey)</para>
+        <para><ulink url="https://trac.osgeo.org/postgis/ticket/5580">5580</ulink>, Handle empty collection components in 3d distance (Paul Ramsey)</para>
+        <para><ulink url="https://trac.osgeo.org/postgis/ticket/5639">5639</ulink>, ST_DFullyWithin line/poly error case (Paul Ramsey)</para>
+        <para><ulink url="https://trac.osgeo.org/postgis/ticket/5662">5662</ulink>, Change XML parsers to SAX2 (Paul Ramsey)</para>
+      </simplesect>
+    </sect1>
     <sect1>
       <title>PostGIS 3.2.6</title>
       <para>2023/11/19</para>
@@ -11,23 +28,23 @@
       Proj 6.1+, and PostgreSQL 14+.</para>
       <simplesect>
-            <para><ulink url="https://trac.osgeo.org/postgis/ticket/"></ulink>5568, Improve robustness of topology face split handling (Sandro Santilli)</para>
-            <para><ulink url="https://trac.osgeo.org/postgis/ticket/"></ulink>5548, Fix box-filtered validity check of topologies with edge-less faces
+            <para><ulink url="https://trac.osgeo.org/postgis/ticket/5568">5568</ulink>, Improve robustness of topology face split handling (Sandro Santilli)</para>
+            <para><ulink url="https://trac.osgeo.org/postgis/ticket/5548">5548</ulink>, Fix box-filtered validity check of topologies with edge-less faces
-            <para><ulink url="https://trac.osgeo.org/postgis/ticket/"></ulink>5494, Fix double-upgrade with view using st_dwithin(text, ...)
+            <para><ulink url="https://trac.osgeo.org/postgis/ticket/5494">5494</ulink>, Fix double-upgrade with view using st_dwithin(text, ...)
-            <para><ulink url="https://trac.osgeo.org/postgis/ticket/"></ulink>5450, Fix macro expansion recursion on powerpc architectures.
+            <para><ulink url="https://trac.osgeo.org/postgis/ticket/5450">5450</ulink>, Fix macro expansion recursion on powerpc architectures.
                       (Bas Couwenberg)</para>
-            <para><ulink url="https://trac.osgeo.org/postgis/ticket/"></ulink>5403, [postgis_topology] Fix ValidateTopology(bbox)
+            <para><ulink url="https://trac.osgeo.org/postgis/ticket/5403">5403</ulink>, [postgis_topology] Fix ValidateTopology(bbox)
                       without topology in search_path (Sandro Santilli)</para>
-            <para><ulink url="https://trac.osgeo.org/postgis/ticket/"></ulink>5410, [postgis_raster] ST_Value bilinear resample,
+            <para><ulink url="https://trac.osgeo.org/postgis/ticket/5410">5410</ulink>, [postgis_raster] ST_Value bilinear resample,
                       don't throw an error if Band has no NODATA value
                       (Regina Obe)</para>
-            <para><ulink url="https://trac.osgeo.org/postgis/ticket/"></ulink>5385, Postgres malloc assertion fail when
+            <para><ulink url="https://trac.osgeo.org/postgis/ticket/5385">5385</ulink>, Postgres malloc assertion fail when
                       using pg_cancel_backend with ST_AsMVT
                       (Regina Obe, Paul Ramsey)</para>
             <para>Fix JsonB casting issue (Paul Ramsey)</para>
-            <para><ulink url="https://trac.osgeo.org/postgis/ticket/"></ulink>5616, Fix to find docbook on newer docbook installs (Regina Obe)</para>
+            <para><ulink url="https://trac.osgeo.org/postgis/ticket/5616">5616</ulink>, Fix to find docbook on newer docbook installs (Regina Obe)</para>
       </simplesect>
     </sect1>
     <sect1>
Summary of changes:
 NEWS                  |  2 +-
 README.postgis        |  4 ++--
 Version.config        |  2 +-
 doc/release_notes.xml | 33 +++++++++++++++++++++++++--------
 4 files changed, 29 insertions(+), 12 deletions(-)
hooks/post-receive
