[PostGIS] #5667: Performance Postgis Topolgy when adding millions by using TopoGeo_AddLineString
PostGIS trac at osgeo.org
Wed Feb 14 00:37:59 PST 2024
  Reporter:  Lars Aksel Opsahl  |      Owner:  strk
      Type:  enhancement        |     Status:  new
  Priority:  medium             |  Milestone:
 Component:  topology           |    Version:  3.4.x
Resolution:                     |   Keywords:  performance
Changes (by strk):
 * keywords:   => performance
Comment:
 I agree about having more batch-loading functions, in general. Such
 function could be taking a generic geometry and was indeed forseen
 already:
 https://git.osgeo.org/gitea/postgis/postgis/src/branch/master/topology/sql/populate.sql.in#L725
 It was planned at least since 2.0.0:
 https://git.osgeo.org/gitea/postgis/postgis/src/tag/2.0.0/topology/sql/populate.sql.in.c#L1057
 In the planned form it had no return, while the implemented functions each
 return a set of identifiers of primitives corresponding to the incoming
 lines. Returning primitives helps in building TopoGeometry objects.
 Your idea of taking an array of lines might help with matching back such a
 sets of primitives to the input geometry they would belong to, so maybe
 the return code of your suggested signature could be a TopoElementArray[]
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5667#comment:2>
