[PostGIS] #5667: Performance Postgis Topolgy when adding millions by using TopoGeo_AddLineString
PostGIS trac at osgeo.org
Wed Feb 14 03:39:50 PST 2024
  Reporter:  Lars Aksel Opsahl  |      Owner:  strk
      Type:  enhancement        |     Status:  new
  Priority:  medium             |  Milestone:
 Component:  topology           |    Version:  3.4.x
Resolution:                     |   Keywords:
Comment (by Lars Aksel Opsahl):
  select version();
        version
  PostgreSQL 12.6 (Ubuntu 12.6-0ubuntu0.20.04.1) on x86_64-pc-linux-gnu,
 compiled by gcc (Ubuntu 9.3.0-17ubuntu1~20.04) 9.3.0, 64-bit
 (1 row)
 vroom5.int.nibio.no postgres at rog_01=# SELECT PostGIS_Full_Version();
 postgis_full_version
  POSTGIS="3.4.0 0874ea3" [EXTENSION] PGSQL="120" GEOS="3.12.1-CAPI-1.18.1"
 (compiled against GEOS 3.10.2) SFCGAL="1.3.7" PROJ="8.2.0
 NETWORK_ENABLED=OFF URL_ENDPOINT=https://cdn.proj.org
 USER_WRITABLE_DIRECTORY=/tmp/proj DATABASE_PATH=/usr/share/proj/proj.db"
 LIBXML="2.9.10" LIBJSON="0.13.1" LIBPROTOBUF="1.3.3" WAGYU="0.5.0
 (Internal)" TOPOLOGY
 (1 row)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5667#comment:7>
