[SCM] PostGIS branch master updated. 3.4.0rc1-930-g8779495f9
Fri Feb 16 06:10:28 PST 2024
the project "PostGIS".
       via  8779495f92373e7b88716186d75f59ff5106b6cb (commit)
      from  963416f2faef21d3461937ed208fca048dd3ab6a (commit)
revisions in full, below.
commit 8779495f92373e7b88716186d75f59ff5106b6cb
Author: Sandro Santilli <strk at kbt.io>
Date:   Fri Feb 16 15:10:12 2024 +0100
    Add timing and increase dataset
diff --git a/topology/test/perf/ST_CreateTopoGeo.sql b/topology/test/perf/ST_CreateTopoGeo.sql
index bb61c4b5f..1a95d6a5e 100644
--- a/topology/test/perf/ST_CreateTopoGeo.sql
+++ b/topology/test/perf/ST_CreateTopoGeo.sql
@@ -3,10 +3,10 @@ SELECT topology.CreateTopology('topoperf');
 --\timing on
 CREATE TABLE topoperf.case_full_coverage_no_holes
-AS SELECT ST_Boundary(geom) g FROM ST_SquareGrid(4, ST_MakeEnvelope(0,0,120,120));
+AS SELECT ST_Boundary(geom) g FROM ST_SquareGrid(2, ST_MakeEnvelope(0,0,120,120));
+\timing on
 SELECT ST_CreateTopoGeo('topoperf', ST_Collect(g))
 FROM topoperf.case_full_coverage_no_holes
-ROLLBACK;
Summary of changes:
 topology/test/perf/ST_CreateTopoGeo.sql | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
hooks/post-receive
