[PostGIS] #5361: Compound Curve inconsistent behavior with ST_GeometryN, ST_NumGeometries, ST_Dump, and ST_DumpSegments
PostGIS trac at osgeo.org
Fri Feb 16 12:42:10 PST 2024
  Reporter:  robe     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  low      |  Milestone:  PostGIS 3.5.0
 Component:  postgis  |    Version:  master
Resolution:           |   Keywords:
Comment (by pramsey):
 Some notes from a consistency check. The main question philosophically is
 whether CompoundCurve and CurvePolygon should be treated as unitary
 objects (like LineString and Polygon) or as collections. Either
 interpretation can result in consistent behaviour, I think.
 https://gist.github.com/pramsey/cbf6db1edb8762854925f6b6ad6d6b35
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5361#comment:10>
