[PostGIS] #5674: ST_CoveredBy(geography, geography) not working for covered polygon with hole
PostGIS trac at osgeo.org
Fri Feb 23 01:42:02 PST 2024
hole
 Reporter:  dbiernacka  |      Owner:  pramsey
     Type:  defect      |     Status:  new
 Priority:  medium      |  Milestone:
Component:  postgis     |    Version:  3.4.x
 Keywords:              |
 Following statement returns false for covered polygon with hole
 select ST_CoveredBy(
   ST_GeographyFromText('POLYGON ((3.845215 46.407564, 3.845215 47.886881,
 7.097168 47.886881, 7.097168 46.407564, 3.845215 46.407564), (6.569824
 46.980252, 5.822754 46.860191, 6.28418 47.561701, 6.569824 46.980252))'),
   ST_GeographyFromText('POLYGON ((1.120605 45.383019, 1.120605 48.661943,
 8.657227 48.661943, 8.657227 45.383019, 1.120605 45.383019))')
 Case when covering polygon contains hole returns true as expected.
 Function ST_CoveredBy with geometry parameters returns true as expected.
 Tested on versions:
 POSTGIS="3.2.3 2f97b6c" [EXTENSION] PGSQL="140" GEOS="3.9.0-CAPI-1.16.2"
 PROJ="7.2.1" LIBXML="2.9.10" LIBJSON="0.15" LIBPROTOBUF="1.3.3"
 WAGYU="0.5.0 (Internal)" TOPOLOGY
 POSTGIS="3.5.0dev 3.4.0rc1-775-g86e698565" [EXTENSION] PGSQL="150"
 GEOS="3.13.0dev-CAPI-1.18.0" PROJ="9.4.0 NETWORK_ENABLED=OFF
 URL_ENDPOINT=https://cdn.proj.org
 USER_WRITABLE_DIRECTORY=/var/lib/postgresql/.local/share/proj
 DATABASE_PATH=/usr/local/share/proj/proj.db" LIBXML="2.9.10"
 LIBJSON="0.15" LIBPROTOBUF="1.3.3" WAGYU="0.5.0 (Internal)" TOPOLOGY
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5674>
