[SCM] PostGIS branch master updated. 3.4.0rc1-943-gb3429f879
Mon Feb 26 09:37:49 PST 2024
the project "PostGIS".
       via  b3429f87992d9e3c884d1ab7243495bff8b2771a (commit)
       via  da85e5361ceafd57dec636c14da114b9b8977f3f (commit)
       via  749373364ce3993682a3e9a48bd724af2f8d25be (commit)
       via  669dc249c082d6f9d92e4858e05e5ac9ca68b481 (commit)
      from  3c79bd65bfad7d0fee01fda56762efa36ffa644f (commit)
revisions in full, below.
commit b3429f87992d9e3c884d1ab7243495bff8b2771a
Merge: 3c79bd65b da85e5361
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Mon Feb 26 09:37:45 2024 -0800
    Merge branch 'rouault-flatbuffers_namespace'
commit da85e5361ceafd57dec636c14da114b9b8977f3f
Author: Andreas Schild <andreas.schild at bfw.gv.at>
Date:   Mon Feb 26 07:14:03 2024 +0000
    Translated PostGIS Manual using Weblate (German)
    Currently translated at 50.1% (2843 of 5667 strings)
    Translation: postgis/PostGIS Manual
    Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/de/
diff --git a/doc/po/de/postgis-manual.po b/doc/po/de/postgis-manual.po
index d6913672e..5ec277c00 100644
--- a/doc/po/de/postgis-manual.po
+++ b/doc/po/de/postgis-manual.po
@@ -3,13 +3,14 @@
 # Regina Obe <regina at arrival3d.com>, 2023, 2024.
 # DeepL <noreply-mt-deepl at weblate.org>, 2024.
+# Andreas Schild <andreas.schild at bfw.gv.at>, 2024.
 msgid ""
 msgstr ""
 "Project-Id-Version: postgis 3.5\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
 "POT-Creation-Date: 2024-01-26 18:34+0000\n"
-"PO-Revision-Date: 2024-01-27 03:24+0000\n"
-"Last-Translator: Regina Obe <regina at arrival3d.com>\n"
+"PO-Revision-Date: 2024-02-26 08:45+0000\n"
+"Last-Translator: Andreas Schild <andreas.schild at bfw.gv.at>\n"
 "Language-Team: German <https://weblate.osgeo.org/projects/postgis/"
 "postgis-manual/de/>\n"
 "Language: de\n"
@@ -35,16 +36,16 @@ msgid "Configuring raster support"
 msgstr "Konfigurieren der Rasterunterstützung"
 #. Tag: para
-#, fuzzy, no-c-format
+#, no-c-format
 msgid ""
 "If you enabled raster support you may want to read below how to properly "
 "configure it."
 msgstr ""
-"Wenn Sie die Rasterunterstützung aktiviert haben, sollten Sie weiter unten "
-"lesen, wie Sie sie richtig konfigurieren."
+"Wenn die Rasterunterstützung aktiviert ist, sollte diese wie folgt "
+"konfiguriert werden."
 #. Tag: para
+#, no-c-format
 msgid ""
 "As of PostGIS 2.1.3, out-of-db rasters and all raster drivers are disabled "
 "by default. In order to re-enable these, you need to set the following "
@@ -53,13 +54,12 @@ msgid ""
 "For PostGIS 2.2, you can use the more cross-platform approach of setting the "
 "corresponding <xref linkend=\"PostGIS_GUC\"/>."
 msgstr ""
-"Ab PostGIS 2.1.3 sind Out-of-DB-Raster und alle Rastertreiber standardmäßig "
-"deaktiviert. Um diese wieder zu aktivieren, müssen Sie die folgenden "
+"Ab PostGIS 2.1.3 sind out-of-db-Raster und alle Rastertreiber von vornherein "
+"deaktiviert. Um diese zu aktivieren, müssen Sie die folgenden "
 "Umgebungsvariablen <varname>POSTGIS_GDAL_ENABLED_DRIVERS</varname> und "
 "<varname>POSTGIS_ENABLE_OUTDB_RASTERS</varname> in der Serverumgebung "
-"setzen. Für PostGIS 2.2 können Sie den plattformübergreifenderen Ansatz "
-"verwenden, indem Sie die entsprechenden <xref linkend=\"PostGIS_GUC\"/> "
-"setzen."
+"setzen. Ab PostGIS 2.2 können Sie einen plattformübergreifenderen Ansatz mit "
+"Hilfe der entsprechenden <xref linkend=\"PostGIS_GUC\"/> verwenden."
 #. Tag: para
@@ -67,34 +67,34 @@ msgid "If you want to enable offline raster:"
 msgstr "Wenn Sie Offline-Raster aktivieren möchten:"
 #. Tag: para
+#, no-c-format
 msgid "Any other setting or no setting at all will disable out of db rasters."
 msgstr ""
-"Jede andere Einstellung oder gar keine Einstellung deaktiviert Out-of-DB-"
-"Raster."
+"Jede andere und auch keine Einstellung deaktiviert die out-of-db Raster."
 #. Tag: para
+#, no-c-format
 msgid ""
 "In order to enable all GDAL drivers available in your GDAL install, set this "
 "environment variable as follows"
 msgstr ""
-"Um alle GDAL-Treiber zu aktivieren, die in Ihrer GDAL-Installation verfügbar "
-"sind, setzen Sie diese Umgebungsvariable wie folgt"
+"Um alle installierten GDAL-Treiber zu aktivieren, muss diese "
+"Umgebungsvariable wie folgt gesetzt werden"
 #. Tag: para
+#, no-c-format
 msgid ""
 "If you want to only enable specific drivers, set your environment variable "
 "as follows:"
 msgstr ""
-"Wenn Sie nur bestimmte Treiber aktivieren möchten, setzen Sie Ihre "
-"Umgebungsvariable wie folgt:"
+"Wenn nur bestimmte Treiber aktiviert werden sollen, muss diese "
+"Umgebungsvariable wie folgt gesetzt werden:"
 #. Tag: para
+#, no-c-format
 msgid "If you are on windows, do not quote the driver list"
-msgstr "Wenn Sie mit Windows arbeiten, zitieren Sie die Treiberliste nicht"
+msgstr ""
+"Unter Windows darf die Treiberliste nicht unter Hochkomma gestellt werden"
 #. Tag: para
commit 749373364ce3993682a3e9a48bd724af2f8d25be
Author: Even Rouault <even.rouault at spatialys.com>
Date:   Sun Feb 25 11:16:45 2024 +0100
    codeql.yml: add 'apt-get update'
    fixes issues like https://github.com/OSGeo/gdal/actions/runs/8032403542/job/21944690464#step:4:126
diff --git a/.github/workflows/codeql.yml b/.github/workflows/codeql.yml
index 2d290d1a6..4fdd1c507 100644
--- a/.github/workflows/codeql.yml
+++ b/.github/workflows/codeql.yml
@@ -53,6 +53,7 @@ jobs:
     - name: Install dependencies
       run: |
+          sudo apt-get update
           sudo apt-get install -y g++ autoconf automake libgeos-dev libproj-dev libgdal-dev libjson-c-dev gettext libxml2-dev postgresql-server-dev-14 postgresql-client-14 libprotobuf-c-dev libprotoc-dev protobuf-c-compiler
     - name: Build
commit 669dc249c082d6f9d92e4858e05e5ac9ca68b481
Date:   Mon Feb 26 02:57:27 2024 +0100
    Make sure our vendored flatbuffers copy has a unique namespace
    Cf https://lists.osgeo.org/pipermail/gdal-dev/2024-February/058544.html
    and https://github.com/OSGeo/gdal/pull/9313
diff --git a/deps/flatgeobuf/Makefile.in b/deps/flatgeobuf/Makefile.in
index 2510cad89..185220def 100644
--- a/deps/flatgeobuf/Makefile.in
+++ b/deps/flatgeobuf/Makefile.in
@@ -29,7 +29,10 @@ srcdir = @srcdir@
 libdir = @libdir@
 CXX = @FLATGEOBUF_CXX@
-CXXFLAGS =-I$(top_srcdir)/liblwgeom -I$(top_builddir)/liblwgeom -I$(srcdir)/include @CPPFLAGS@ @CXXFLAGS@ @PICFLAGS@
+# This ugly -Dflatbuffers=postgis_flatbuffers is to prevent potential subtle
+# clash with other flatbuffers copies that could come from GDAL or its
+# dependencies.
+CXXFLAGS =-I$(top_srcdir)/liblwgeom -I$(top_builddir)/liblwgeom -I$(srcdir)/include @CPPFLAGS@ @CXXFLAGS@ @PICFLAGS@ -Dflatbuffers=postgis_flatbuffers
 LDFLAGS = @LDFLAGS@
 LIBTOOL = @LIBTOOL@
Summary of changes:
 deps/flatgeobuf/Makefile.in | 5 ++++-
 1 file changed, 4 insertions(+), 1 deletion(-)
hooks/post-receive
