[SCM] PostGIS branch master updated. 3.4.0rc1-944-g15c8d95ef
Mon Feb 26 11:30:47 PST 2024
the project "PostGIS".
       via  15c8d95efcff17d1d1b993a3e5480cb7c490760b (commit)
      from  b3429f87992d9e3c884d1ab7243495bff8b2771a (commit)
revisions in full, below.
commit 15c8d95efcff17d1d1b993a3e5480cb7c490760b
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Mon Feb 26 11:23:46 2024 -0800
    Union the contents of a single-member array before returning, so that collections get flattened. References #5677
diff --git a/postgis/lwgeom_geos.c b/postgis/lwgeom_geos.c
index 4ee151cba..92b2b5f53 100644
--- a/postgis/lwgeom_geos.c
+++ b/postgis/lwgeom_geos.c
@@ -600,6 +600,9 @@ Datum pgis_union_geometry_array(PG_FUNCTION_ARGS)
 	if ( count == 0 )
 		PG_RETURN_NULL();
+	/* Ok, we really need GEOS now ;) */
+	initGEOS(lwpgnotice, lwgeom_geos_error);
 	/* One geom, good geom? Return it */
 	if ( count == 1 && nelems == 1 )
@@ -607,15 +610,19 @@ Datum pgis_union_geometry_array(PG_FUNCTION_ARGS)
 #pragma GCC diagnostic push
 #pragma GCC diagnostic ignored "-Wsign-compare"
 #endif
-		PG_RETURN_POINTER((GSERIALIZED *)(ARR_DATA_PTR(array)));
+		g = POSTGIS2GEOS((GSERIALIZED *)(ARR_DATA_PTR(array)));
 #if __GNUC__ > 4 || (__GNUC__ == 4 && __GNUC_MINOR__ >= 6)
 #pragma GCC diagnostic pop
 #endif
+		g_union = GEOSUnaryUnion(g);
+		GEOSGeom_destroy(g);
+		if (!g_union) HANDLE_GEOS_ERROR("GEOSUnaryUnion");
+		GEOSSetSRID(g_union, srid);
+		gser_out = GEOS2POSTGIS(g_union, is3d);
+		GEOSGeom_destroy(g_union);
+		PG_RETURN_POINTER(gser_out);
-	/* Ok, we really need GEOS now ;) */
-	initGEOS(lwpgnotice, lwgeom_geos_error);
 	** Collect the non-empty inputs and stuff them into a GEOS collection
Summary of changes:
 postgis/lwgeom_geos.c | 15 +++++++++++----
 1 file changed, 11 insertions(+), 4 deletions(-)
hooks/post-receive
