[SCM] PostGIS branch master updated. 3.4.0rc1-946-gabf836f0a
Wed Feb 28 00:26:11 PST 2024
the project "PostGIS".
       via  abf836f0acc0c1540dad27fe700cdf60e766f018 (commit)
      from  6896fe0fe7d277e586cc116eed56805e967417a2 (commit)
revisions in full, below.
commit abf836f0acc0c1540dad27fe700cdf60e766f018
Author: Sandro Santilli <strk at kbt.io>
Date:   Wed Feb 28 09:27:15 2024 +0100
    Add scripts to enable and show stats
diff --git a/topology/test/perf/enable_stats.sql b/topology/test/perf/enable_stats.sql
new file mode 100644
index 000000000..ab8eb0ba5
--- /dev/null
+++ b/topology/test/perf/enable_stats.sql
@@ -0,0 +1,4 @@
+-- See https://www.postgresql.org/docs/current/pgstatstatements.html
+CREATE EXTENSION IF NOT EXISTS pg_stat_statements;
+SET pg_stat_statements.track to 'all';
+SELECT pg_stat_statements_reset();
diff --git a/topology/test/perf/show_stats.sql b/topology/test/perf/show_stats.sql
index 000000000..52e477f2b
--- /dev/null
+++ b/topology/test/perf/show_stats.sql
@@ -0,0 +1,15 @@
+SELECT
+  calls,
+  round(total_exec_time) tot_ms,
+  substring(
+    regexp_replace(
+      regexp_replace(query,'\n',' ','g'),
+      'g'
+    from 1 for 90
+  ) query
+FROM pg_stat_statements
+ORDER BY total_exec_time desc;
Summary of changes:
 topology/test/perf/enable_stats.sql |  4 ++++
 topology/test/perf/show_stats.sql   | 15 +++++++++++++++
 2 files changed, 19 insertions(+)
 create mode 100644 topology/test/perf/enable_stats.sql
 create mode 100644 topology/test/perf/show_stats.sql
hooks/post-receive
