[PostGIS] #5680: populate_topology_layer does not work as documented
PostGIS trac at osgeo.org
Wed Feb 28 03:21:11 PST 2024
 Reporter:  strk      |      Owner:  strk
     Type:  defect    |     Status:  new
 Priority:  medium    |  Milestone:  PostGIS 3.5.0
Component:  topology  |    Version:  master
 Keywords:            |
 This documented function does not do what is expected to do:
 https://postgis.net/docs/manual-3.3/Populate_Topology_Layer.html
 It is also lacking a testcase.
 The implementation is also source of a WARNING about escaped strings (
 #5678 )
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5680>
