[PostGIS] #5680: populate_topology_layer does not work as documented
PostGIS trac at osgeo.org
Wed Feb 28 03:59:56 PST 2024
  Reporter:  strk      |      Owner:  strk
      Type:  defect    |     Status:  new
  Priority:  medium    |  Milestone:  PostGIS 3.5.0
 Component:  topology  |    Version:  master
Resolution:            |   Keywords:
Comment (by strk):
 it turns out the problem is related to #5678 because the function works
 fine when `standard_conforming_strings` are off
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5680#comment:2>
