[SCM] PostGIS branch master updated. 3.4.0rc1-948-g02580d807
Wed Feb 28 05:14:10 PST 2024
the project "PostGIS".
       via  02580d807eb050424b2ee76eb17144a684a7a9a8 (commit)
      from  553258b55940d0774098cadcf0522e307c0c7b39 (commit)
revisions in full, below.
commit 02580d807eb050424b2ee76eb17144a684a7a9a8
Author: Loïc Bartoletti <loic.bartoletti at oslandia.com>
Date:   Wed Feb 28 13:46:41 2024 +0100
    sfcgal.sql.in: Fix extra COMMIT; statements
    Closes #5679
diff --git a/sfcgal/sfcgal.sql.in b/sfcgal/sfcgal.sql.in
index 7d64ee3c1..b5dcf130a 100644
--- a/sfcgal/sfcgal.sql.in
+++ b/sfcgal/sfcgal.sql.in
@@ -164,7 +164,6 @@ CREATE OR REPLACE FUNCTION ST_ConstrainedDelaunayTriangles(geometry)
        AS 'MODULE_PATHNAME', 'ST_ConstrainedDelaunayTriangles'
        LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE
        COST 100;
-COMMIT;
 -- Availability: 3.3.0
 CREATE OR REPLACE FUNCTION ST_3DConvexHull(geometry)
@@ -172,7 +171,6 @@ CREATE OR REPLACE FUNCTION ST_3DConvexHull(geometry)
        AS 'MODULE_PATHNAME', 'sfcgal_convexhull3D'
        COST 100;
-COMMIT;
 CREATE OR REPLACE FUNCTION ST_AlphaShape(g1 geometry, alpha float8 DEFAULT 1.0, allow_holes boolean DEFAULT false)
@@ -180,7 +178,6 @@ CREATE OR REPLACE FUNCTION ST_AlphaShape(g1 geometry, alpha float8 DEFAULT 1.0,
        AS 'MODULE_PATHNAME', 'sfcgal_alphashape'
        COST 100;
-COMMIT;
 CREATE OR REPLACE FUNCTION ST_OptimalAlphaShape(g1 geometry, allow_holes boolean DEFAULT false, nb_components int DEFAULT 1)
@@ -188,7 +185,6 @@ CREATE OR REPLACE FUNCTION ST_OptimalAlphaShape(g1 geometry, allow_holes boolean
        AS 'MODULE_PATHNAME', 'sfcgal_optimalalphashape'
        COST 100;
-COMMIT;
 -- Availability: 3.5.0
 CREATE OR REPLACE FUNCTION CG_YMonotonePartition(g1 geometry)
@@ -196,7 +192,6 @@ CREATE OR REPLACE FUNCTION CG_YMonotonePartition(g1 geometry)
        AS 'MODULE_PATHNAME', 'sfcgal_ymonotonepartition'
        COST 100;
-COMMIT;
 CREATE OR REPLACE FUNCTION CG_ApproxConvexPartition(g1 geometry)
@@ -204,7 +199,6 @@ CREATE OR REPLACE FUNCTION CG_ApproxConvexPartition(g1 geometry)
        AS 'MODULE_PATHNAME', 'sfcgal_approxconvexpartition'
        COST 100;
-COMMIT;
 CREATE OR REPLACE FUNCTION CG_GreeneApproxConvexPartition(g1 geometry)
@@ -212,7 +206,6 @@ CREATE OR REPLACE FUNCTION CG_GreeneApproxConvexPartition(g1 geometry)
        AS 'MODULE_PATHNAME', 'sfcgal_greeneapproxconvexpartition'
        COST 100;
-COMMIT;
 CREATE OR REPLACE FUNCTION CG_OptimalConvexPartition(g1 geometry)
@@ -220,7 +213,6 @@ CREATE OR REPLACE FUNCTION CG_OptimalConvexPartition(g1 geometry)
        AS 'MODULE_PATHNAME', 'sfcgal_optimalconvexpartition'
        COST 100;
-COMMIT;
 CREATE OR REPLACE FUNCTION CG_ExtrudeStraightSkeleton(g1 geometry, top_height float8, body_height float8 DEFAULT 0.0)
@@ -228,7 +220,6 @@ CREATE OR REPLACE FUNCTION CG_ExtrudeStraightSkeleton(g1 geometry, top_height fl
        AS 'MODULE_PATHNAME', 'sfcgal_extrudestraightskeleton'
        COST 100;
-COMMIT;
 CREATE OR REPLACE FUNCTION CG_Visibility(polygon geometry, pointA geometry, pointB geometry)
@@ -236,7 +227,6 @@ CREATE OR REPLACE FUNCTION CG_Visibility(polygon geometry, pointA geometry, poin
        AS 'MODULE_PATHNAME', 'sfcgal_visibility_segment'
        COST 100;
-COMMIT;
 CREATE OR REPLACE FUNCTION CG_Visibility(polygon geometry, point geometry)
@@ -244,4 +234,5 @@ CREATE OR REPLACE FUNCTION CG_Visibility(polygon geometry, point geometry)
        AS 'MODULE_PATHNAME', 'sfcgal_visibility_point'
        COST 100;
 COMMIT;
Summary of changes:
 sfcgal/sfcgal.sql.in | 11 +----------
 1 file changed, 1 insertion(+), 10 deletions(-)
hooks/post-receive
