[SCM] PostGIS branch master updated. 3.4.0rc1-949-gf64b082ef
Wed Feb 28 05:45:10 PST 2024
the project "PostGIS".
       via  f64b082efca3986205253ffee3fd0f1b421ee0db (commit)
      from  02580d807eb050424b2ee76eb17144a684a7a9a8 (commit)
revisions in full, below.
commit f64b082efca3986205253ffee3fd0f1b421ee0db
Author: Sandro Santilli <strk at kbt.io>
Date:   Wed Feb 28 12:29:11 2024 +0100
    Fix populate_topology_layer with conforming strings off
    References #5680, #5678 in master branch (3.5.0dev)
    Includes test
diff --git a/topology/test/regress/populate_topology_layer.sql b/topology/test/regress/populate_topology_layer.sql
new file mode 100644
index 000000000..8801f7b3b
--- /dev/null
+++ b/topology/test/regress/populate_topology_layer.sql
@@ -0,0 +1,37 @@
+BEGIN;
+SELECT NULL FROM topology.CreateTopology('x');
+CREATE TABLE x.f(id int primary key);
+SELECT NULL FROM topology.AddTopoGeometryColumn('x', 'x', 'f', 'g0', 'POINT');
+SELECT NULL FROM topology.AddTopoGeometryColumn('x', 'x', 'f', 'g1', 'LINE');
+SELECT NULL FROM topology.AddTopoGeometryColumn('x', 'x', 'f', 'g2', 'POLYGON');
+SELECT NULL FROM topology.AddTopoGeometryColumn('x', 'x', 'f', 'g3', 'GEOMETRYCOLLECTION');
+CREATE TABLE layer_backup AS SELECT * FROM topology.layer;
+SELECT 'initial',
+ layer_id,
+ schema_name,
+ table_name,
+ feature_column,
+ feature_type,
+ level,
+ child_id
+FROM topology.layer ORDER BY schema_name, table_name, feature_column;
+TRUNCATE topology.layer;
+SELECT 'populate', * FROM topology.Populate_Topology_Layer();
+SELECT 'only-before', * FROM ( SELECT * FROM topology.layer EXCEPT SELECT * FROM layer_backup ) x;
+SELECT 'only-after', * FROM ( SELECT * FROM layer_backup EXCEPT SELECT * FROM topology.layer ) x;
+SELECT 'final',
+ layer_id,
+ schema_name,
+ table_name,
+ feature_column,
+ feature_type,
+ level,
+ child_id
diff --git a/topology/test/regress/populate_topology_layer_expected b/topology/test/regress/populate_topology_layer_expected
index 000000000..6acedee11
--- /dev/null
+++ b/topology/test/regress/populate_topology_layer_expected
@@ -0,0 +1,12 @@
+initial|1|x|f|g0|1|0|
+initial|2|x|f|g1|2|0|
+initial|3|x|f|g2|3|0|
+initial|4|x|f|g3|4|0|
+populate|x|f|g0
+populate|x|f|g1
+populate|x|f|g2
+populate|x|f|g3
+final|1|x|f|g0|1|0|
+final|2|x|f|g1|2|0|
+final|3|x|f|g2|3|0|
+final|4|x|f|g3|4|0|
diff --git a/topology/test/tests.mk b/topology/test/tests.mk
index cd0d26d32..716fe291a 100644
--- a/topology/test/tests.mk
+++ b/topology/test/tests.mk
@@ -46,6 +46,7 @@ TESTS += \
 	$(top_srcdir)/topology/test/regress/legacy_query.sql \
 	$(top_srcdir)/topology/test/regress/legacy_validate.sql \
 	$(top_srcdir)/topology/test/regress/polygonize.sql \
+	$(top_srcdir)/topology/test/regress/populate_topology_layer.sql \
 	$(top_srcdir)/topology/test/regress/removeunusedprimitives.sql \
 	$(top_srcdir)/topology/test/regress/renametopology.sql \
 	$(top_srcdir)/topology/test/regress/renametopogeometrycolumn.sql \
diff --git a/topology/topology.sql.in b/topology/topology.sql.in
index 97c0e3926..5746794c5 100644
--- a/topology/topology.sql.in
+++ b/topology/topology.sql.in
@@ -670,7 +670,7 @@ $$
     replace(c.conname, 'check_topogeom_', '') col,
     --c.consrc src,
     regexp_matches(c.consrc,
-      '\.topology_id = (\d+).*\.layer_id = (\d+).*\.type = (\d+)') inf
+      E'\\.topology_id = (\\d+).*\\.layer_id = (\\d+).*\\.type = (\\d+)') inf
   FROM (SELECT conname, connamespace, conrelid, conkey, pg_get_constraintdef(oid) As consrc
 		    FROM pg_constraint) AS c, pg_class r, pg_namespace n
   WHERE c.conname LIKE 'check_topogeom_%'
Summary of changes:
 topology/test/regress/populate_topology_layer.sql  | 37 ++++++++++++++++++++++
 .../test/regress/populate_topology_layer_expected  | 12 +++++++
 topology/test/tests.mk                             |  1 +
 topology/topology.sql.in                           |  2 +-
 4 files changed, 51 insertions(+), 1 deletion(-)
 create mode 100644 topology/test/regress/populate_topology_layer.sql
 create mode 100644 topology/test/regress/populate_topology_layer_expected
hooks/post-receive
