[PostGIS] #5680: populate_topology_layer does not work as documented
PostGIS trac at osgeo.org
Wed Feb 28 05:47:35 PST 2024
  Reporter:  strk      |      Owner:  strk
      Type:  defect    |     Status:  closed
  Priority:  medium    |  Milestone:  PostGIS 3.5.0
 Component:  topology  |    Version:  master
Resolution:  fixed     |   Keywords:
Changes (by Sandro Santilli <strk@…>):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"71afa3e0e349f7d6f4df741d803d03bc01b10200/git" 71afa3e/git]:
 {{{#!CommitTicketReference repository="git"
 revision="71afa3e0e349f7d6f4df741d803d03bc01b10200"
 Fix populate_topology_layer with conforming strings off
 Closes #5680, #5678 in 3.3 branch (3.3.7dev)
 Includes test
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5680#comment:6>
