[SCM] PostGIS branch stable-3.4 updated. 3.4.2-7-g1d1d8d83a
Thu Feb 29 00:09:51 PST 2024
the project "PostGIS".
The branch, stable-3.4 has been updated
       via  1d1d8d83a1d139c06a9f4069430a86f3e00e2596 (commit)
      from  c3093e5750d32aab72602a479c1c5502ef3c08ca (commit)
revisions in full, below.
commit 1d1d8d83a1d139c06a9f4069430a86f3e00e2596
Author: Sandro Santilli <strk at kbt.io>
Date:   Thu Feb 29 09:08:16 2024 +0100
    Make populate_topology_layer test predictable (order by)
    See https://woodie.osgeo.org/repos/30/pipeline/1847/13#L9455
diff --git a/topology/test/regress/populate_topology_layer.sql b/topology/test/regress/populate_topology_layer.sql
index 8801f7b3b..c35218a18 100644
--- a/topology/test/regress/populate_topology_layer.sql
+++ b/topology/test/regress/populate_topology_layer.sql
@@ -21,7 +21,8 @@ FROM topology.layer ORDER BY schema_name, table_name, feature_column;
 TRUNCATE topology.layer;
-SELECT 'populate', * FROM topology.Populate_Topology_Layer();
+SELECT 'populate', * FROM topology.Populate_Topology_Layer()
+ORDER BY schema_name, table_name, feature_column;
 SELECT 'only-before', * FROM ( SELECT * FROM topology.layer EXCEPT SELECT * FROM layer_backup ) x;
 SELECT 'only-after', * FROM ( SELECT * FROM layer_backup EXCEPT SELECT * FROM topology.layer ) x;
Summary of changes:
 topology/test/regress/populate_topology_layer.sql | 3 ++-
 1 file changed, 2 insertions(+), 1 deletion(-)
hooks/post-receive
