[PostGIS] #5682: Bug in geometry_columns view
PostGIS trac at osgeo.org
Thu Feb 29 02:11:47 PST 2024
  Reporter:  jonochang  |      Owner:  pramsey
      Type:  defect     |     Status:  new
  Priority:  medium     |  Milestone:
 Component:  postgis    |    Version:  3.4.x
Resolution:             |   Keywords:
Description changed by jonochang:
Old description:
> We have encountered a bug in the geometry_columns view where the subquery
> which returns ndims for a constraint assumes a certain format that does
> not work with contraints used by other libraries.
> See this section here:
> https://github.com/postgis/postgis/blob/8a41ae8f4bf7fe533f16bda1a998e61a460ed211/postgis/postgis.sql.in#L6422
> and an example constraint here in the attached test-schema.sql:
>   81   │     job_schema_version integer DEFAULT 1,
>   82   │     CONSTRAINT valid_queues CHECK (((array_ndims(queues) = 1)
> AND (array_length(queues, 1) IS NOT NULL))),
>   83   │     CONSTRAINT valid_worker_priorities CHECK
> (((array_ndims(worker_priorities) = 1) AND
> (array_length(worker_priorities, 1) IS NOT NULL)))
>   84   │ );
> An example output from the attached failing query test-query.sql is here:
> postgis_full_version
>  POSTGIS="3.4.1 ca035b9" [EXTENSION] PGSQL="160"
> GEOS="3.12.1-CAPI-1.18.1" PROJ="9.2.1 NETWORK_ENABLED=OFF
> URL_ENDPOINT=https://cdn.proj.org
> USER_WRITABLE_DIRECTORY=/Users/jonochang/Library/Application Support/proj
> DATABASE_PATH=/Applications/Postgres.app/Contents/Versions/16/share/proj/proj.db"
> LIBXML="2.11.7" LIBJSON="0.17" LIBPROTOBUF="1.4.1" WAGYU="0.5.0
> (Internal)"
> (1 row)
>                                                               version
>  PostgreSQL 16.2 (Postgres.app) on aarch64-apple-darwin21.6.0, compiled
> by Apple clang version 14.0.0 (clang-1400.0.29.102), 64-bit
> (1 row)
> ERROR:  invalid input syntax for type integer: "1 AND
> (array_length(queues, 1 IS NOT NULL"
> ❯ psql -h localhost postgis_error_simple < test-query.sql
> ❯ vim test-query.sql
> ❯ psql -a -h localhost postgis_error_simple < test-query.sql
> SELECT postgis_full_version();
> (Internal)"
> (1 row)
> SELECT version();
>                                                               version
> (1 row)
> select * from geometry_columns WHERE f_table_name = 'items';
New description:
   82   │     CONSTRAINT valid_queues CHECK (((array_ndims(queues) = 1) AND
   84   │ );
  POSTGIS="3.4.1 ca035b9" [EXTENSION] PGSQL="160" GEOS="3.12.1-CAPI-1.18.1"
 PROJ="9.2.1 NETWORK_ENABLED=OFF URL_ENDPOINT=https://cdn.proj.org
 (Internal)"
 (1 row)
 SELECT version();
                                                               version
  PostgreSQL 16.2 (Postgres.app) on aarch64-apple-darwin21.6.0, compiled by
 (1 row)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5682#comment:1>
