[SCM] PostGIS branch master updated. 3.4.0rc1-873-g276632b76
Mon Jan 8 15:31:06 PST 2024
the project "PostGIS".
       via  276632b767e7f01206d383e5f71e3b4c03c22307 (commit)
      from  5c7c2c3ee7c9d8f03c8c7ac1a1c3cc555400dd2a (commit)
revisions in full, below.
commit 276632b767e7f01206d383e5f71e3b4c03c22307
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Mon Jan 8 15:31:00 2024 -0800
    Clarify documentation page typos regarding gdal_vsi_options, references #5653
diff --git a/doc/reference_guc.xml b/doc/reference_guc.xml
index b78a57a07..4efc5b0c5 100644
--- a/doc/reference_guc.xml
+++ b/doc/reference_guc.xml
@@ -261,7 +261,7 @@ SELECT pg_reload_conf();
   <refentry xml:id="postgis_gdal_vsi_options">
             <refnamediv>
-                <refname>postgis.gdal_config_options</refname>
+                <refname>postgis.gdal_vsi_options</refname>
                 <refpurpose>
                     A string configuration to set options used when working with an out-db raster.
                 </refpurpose>
@@ -282,12 +282,12 @@ SELECT pg_reload_conf();
                 <para>Set <varname>postgis.gdal_vsi_options</varname> for current session:</para>
                 <programlisting>
-SET postgis.gdal_config_options = 'AWS_ACCESS_KEY_ID=xxxxxxxxxxxxxxx AWS_SECRET_ACCESS_KEY=yyyyyyyyyyyyyyyyyyyyyyyyyy';
+SET postgis.gdal_vsi_options = 'AWS_ACCESS_KEY_ID=xxxxxxxxxxxxxxx AWS_SECRET_ACCESS_KEY=yyyyyyyyyyyyyyyyyyyyyyyyyy';
                 </programlisting>
                 <para>Set <varname>postgis.gdal_vsi_options</varname> just for the <emphasis>current transaction</emphasis> using the <varname>LOCAL</varname> keyword:</para>
                 <programlisting>
-SET LOCAL postgis.gdal_config_options = 'AWS_ACCESS_KEY_ID=xxxxxxxxxxxxxxx AWS_SECRET_ACCESS_KEY=yyyyyyyyyyyyyyyyyyyyyyyyyy';
+SET LOCAL postgis.gdal_vsi_options = 'AWS_ACCESS_KEY_ID=xxxxxxxxxxxxxxx AWS_SECRET_ACCESS_KEY=yyyyyyyyyyyyyyyyyyyyyyyyyy';
                 </programlisting>
             </refsection>
Summary of changes:
 doc/reference_guc.xml | 6 +++---
 1 file changed, 3 insertions(+), 3 deletions(-)
hooks/post-receive
