[SCM] PostGIS branch master updated. 3.4.0rc1-875-g51ff306d3
Tue Jan 9 12:44:57 PST 2024
the project "PostGIS".
       via  51ff306d3f32217d00e9511cfe9463ddb0523adb (commit)
      from  c5b42369ac1ee6ea87433e6237bfb19505976dc8 (commit)
revisions in full, below.
commit 51ff306d3f32217d00e9511cfe9463ddb0523adb
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Tue Jan 9 12:44:47 2024 -0800
    Fix logic mistake in ST_Covers for geography
diff --git a/liblwgeom/lwgeodetic.c b/liblwgeom/lwgeodetic.c
index 89cf47589..982e4e4af 100644
--- a/liblwgeom/lwgeodetic.c
+++ b/liblwgeom/lwgeodetic.c
@@ -2637,23 +2637,10 @@ int lwpoly_covers_lwpoly(const LWPOLY *poly1, const LWPOLY *poly2)
 	/* check if all vertices of poly2 are inside poly1 */
 	for (i = 0; i < poly2->nrings; i++)
-		/* every other ring is a hole, check if point is inside the actual polygon */
-		if ( i % 2 == 0)
+		if (LW_FALSE == lwpoly_covers_pointarray(poly1, poly2->rings[i]))
-			if (LW_FALSE == lwpoly_covers_pointarray(poly1, poly2->rings[i]))
-				LWDEBUG(4,"returning false, geometry2 has point outside of geometry1");
-				return LW_FALSE;
-		else
-			if (LW_TRUE == lwpoly_covers_pointarray(poly1, poly2->rings[i]))
-				LWDEBUG(4,"returning false, geometry2 has point inside a hole of geometry1");
-				return LW_FALSE;
+			LWDEBUG(4,"returning false, geometry2 has point outside of geometry1");
+			return LW_FALSE;
diff --git a/regress/core/geography_covers.sql b/regress/core/geography_covers.sql
index 2bae7880e..721f2431a 100644
--- a/regress/core/geography_covers.sql
+++ b/regress/core/geography_covers.sql
@@ -42,3 +42,9 @@ SELECT c, ST_Covers(g::geography, g::geography) FROM
     ('geog_covers_self_line', 'LINESTRING (35 35, 35 15, 15 15)'),
     ('geog_covers_self_polygon', 'POLYGON((0 40, 40 40, 40 0, 0 0, 0 40))')
 ) AS u(c, g)
+-- donut covers
+SELECT 'geog_covers_donut', ST_Covers(
+	ST_BUFFER('Point(0 0)'::geography, 50000),
+	'Polygon((0.1 0.2, 0.1 0.3, 0.2 0.3, 0.2 0.2, 0.1 0.2), (0.15 0.22, 0.15 0.25, 0.18 0.25, 0.18 0.22, 0.15 0.22))'::geography
diff --git a/regress/core/geography_covers_expected b/regress/core/geography_covers_expected
index 792ccc537..e35d961af 100644
--- a/regress/core/geography_covers_expected
+++ b/regress/core/geography_covers_expected
@@ -17,3 +17,4 @@ geog_covered_poly_line_out|f
 geog_covers_self_point|t
 geog_covers_self_line|t
 geog_covers_self_polygon|t
+geog_covers_donut|t
diff --git a/regress/core/tickets.sql b/regress/core/tickets.sql
index c07cbf688..be93a47cb 100644
--- a/regress/core/tickets.sql
+++ b/regress/core/tickets.sql
@@ -1526,3 +1526,4 @@ SELECT '#5604',
 FROM
 ST_GeomFromText('MULTIPOINT((-2 0), EMPTY)') AS a1,
 ST_GeomFromText('MULTIPOINT((1 0),(0 0))') AS a2;
Summary of changes:
 liblwgeom/lwgeodetic.c                 | 19 +++----------------
 regress/core/geography_covers.sql      |  6 ++++++
 regress/core/geography_covers_expected |  1 +
 regress/core/tickets.sql               |  1 +
 4 files changed, 11 insertions(+), 16 deletions(-)
hooks/post-receive
