[SCM] PostGIS branch stable-3.4 updated. 3.4.1-29-gbf05b12dd
Tue Jan 9 12:57:34 PST 2024
the project "PostGIS".
The branch, stable-3.4 has been updated
       via  bf05b12dd396bd9b99145b1dfe53880f8f7a130b (commit)
       via  43117dae2b94a8cd6a12c8850c9c9c59ca3f8598 (commit)
      from  b286dd218e8976bf0c9ec4629677e0f0f23f8fcc (commit)
revisions in full, below.
commit bf05b12dd396bd9b99145b1dfe53880f8f7a130b
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Tue Jan 9 12:57:29 2024 -0800
    Update news to reflect #5647
diff --git a/NEWS b/NEWS
index 6980c40fa..bbf28ffeb 100644
--- a/NEWS
+++ b/NEWS
@@ -11,7 +11,7 @@ To take advantage of all SFCGAL featurs, SFCGAL 1.4.1+ is needed.
  - #5571, Memory over-allocation for narrow inputs (Paul Ramsey)
  - #5610, Regression fix: Allow Nan and infinity again
           in ST_SetPoint (Regina Obe)
- - #5627, Handling of EMPTY components in PiP check (Paul Ramsey)
+ - #5627, #5647, Handling of EMPTY components in PiP check (Paul Ramsey)
  - #5629, Handling EMPTY components in repeated point removal (Paul Ramsey)
  - #5604, Handle distance between collections with empty elements (Paul Ramsey)
  - #5635, Handle NaN points in ST_Split (Regina Obe)
commit 43117dae2b94a8cd6a12c8850c9c9c59ca3f8598
Date:   Tue Jan 9 12:56:37 2024 -0800
    Handle empty components of MULTIPOINT in native point-in-polygon routines, references #5647
diff --git a/postgis/lwgeom_geos.c b/postgis/lwgeom_geos.c
index 8871d781e..28b5c3e68 100644
--- a/postgis/lwgeom_geos.c
+++ b/postgis/lwgeom_geos.c
@@ -140,7 +140,6 @@ static int
 pip_short_circuit(RTREE_POLY_CACHE *poly_cache, LWPOINT *point, const GSERIALIZED *gpoly)
 	int result;
 	if ( poly_cache && poly_cache->ringIndices )
         result = point_in_multipolygon_rtree(poly_cache->ringIndices, poly_cache->polyCount, poly_cache->ringCounts, point);
@@ -1913,18 +1912,20 @@ Datum contains(PG_FUNCTION_ARGS)
 		else if (gserialized_get_type(gpoint) == MULTIPOINTTYPE)
 			LWMPOINT* mpoint = lwgeom_as_lwmpoint(lwgeom_from_gserialized(gpoint));
-			uint32_t i;
 			int found_completely_inside = LW_FALSE;
 			retval = LW_TRUE;
-			for (i = 0; i < mpoint->ngeoms; i++)
+			for (uint32_t i = 0; i < mpoint->ngeoms; i++)
+				int pip_result;
+				LWPOINT* pt = mpoint->geoms[i];
 				/* We need to find at least one point that's completely inside the
 				 * polygons (pip_result == 1).  As long as we have one point that's
 				 * completely inside, we can have as many as we want on the boundary
 				 * itself. (pip_result == 0)
-				int pip_result = pip_short_circuit(cache, mpoint->geoms[i], gpoly);
+				if (lwpoint_is_empty(pt)) continue;
+				pip_result = pip_short_circuit(cache, pt, gpoly);
 				if (pip_result == 1)
 					found_completely_inside = LW_TRUE;
@@ -2123,8 +2124,9 @@ Datum covers(PG_FUNCTION_ARGS)
 			retval = LW_TRUE;
-				if (pip_result == -1)
+				LWPOINT *pt = mpoint->geoms[i];
+				if (pip_short_circuit(cache, pt, gpoly) == -1)
 					retval = LW_FALSE;
 					break;
@@ -2255,8 +2257,9 @@ Datum coveredby(PG_FUNCTION_ARGS)
 			retval = LW_TRUE;
 					retval = LW_FALSE;
 					break;
@@ -2413,13 +2416,12 @@ Datum ST_Intersects(PG_FUNCTION_ARGS)
-			uint32_t i;
 			retval = LW_FALSE;
-				if (pip_result != -1) /* not outside */
+				if (pip_short_circuit(cache, pt, gpoly) != -1) /* not outside */
 					retval = LW_TRUE;
 					break;
diff --git a/regress/core/tickets.sql b/regress/core/tickets.sql
index 6623d3fca..a5e9f4cc9 100644
--- a/regress/core/tickets.sql
+++ b/regress/core/tickets.sql
@@ -1526,3 +1526,23 @@ SELECT '#5604',
 FROM
 ST_GeomFromText('MULTIPOINT((-2 0), EMPTY)') AS a1,
 ST_GeomFromText('MULTIPOINT((1 0),(0 0))') AS a2;
+WITH g AS (
+SELECT
+ 'POINT EMPTY'::geometry AS emptypt,
+ 'MULTIPOINT(EMPTY,-392 574)'::geometry AS mixedemptypt,
+ 'POLYGON((-357 477,-392 574,-378 574,-357 477))'::geometry AS poly
+SELECT '#5647' AS ticket,
+ 'intersects_empty '       || ST_Intersects(emptypt, poly),
+ 'within_empty '           || ST_Within(emptypt, poly),
+ 'contains_empty '         || ST_Contains(emptypt, poly),
+ 'coveredby_empty '        || ST_CoveredBy(emptypt, poly),
+ 'covers_empty '           || ST_Covers(poly, emptypt),
+ 'intersects_mixed_empty ' || ST_Intersects(mixedemptypt, poly),
+ 'within_mixed_empty '     || ST_Within(mixedemptypt, poly),
+ 'contains_mixed_empty '   || ST_Contains(mixedemptypt, poly),
+ 'coveredby_mixed_empty '  || ST_CoveredBy(mixedemptypt, poly),
+ 'covers_mixed_empty '     || ST_Covers(poly, mixedemptypt)
+FROM g, generate_series(1,2);
diff --git a/regress/core/tickets_expected b/regress/core/tickets_expected
index f9ae3a346..65c7b2993 100644
--- a/regress/core/tickets_expected
+++ b/regress/core/tickets_expected
@@ -470,3 +470,5 @@ ERROR:  Geometry contains invalid coordinates
 #5378|4269
 #5627|t
 #5604|2|POINT(0 0)|2|POINT(-2 0)
+#5647|intersects_empty false|within_empty false|contains_empty false|coveredby_empty false|covers_empty false|intersects_mixed_empty true|within_mixed_empty false|contains_mixed_empty false|coveredby_mixed_empty true|covers_mixed_empty true
Summary of changes:
 NEWS                          |  2 +-
 postgis/lwgeom_geos.c         | 28 +++++++++++++++-------------
 regress/core/tickets.sql      | 20 ++++++++++++++++++++
 regress/core/tickets_expected |  2 ++
 4 files changed, 38 insertions(+), 14 deletions(-)
hooks/post-receive
