[SCM] PostGIS branch stable-3.1 updated. 3.1.10-14-ge64ae3be8
Tue Jan 9 14:22:44 PST 2024
the project "PostGIS".
The branch, stable-3.1 has been updated
       via  e64ae3be8b57e1948210afe5df0c46274dc0c039 (commit)
      from  871d365dfb421f886490a766a2a212ac9be0a123 (commit)
revisions in full, below.
commit e64ae3be8b57e1948210afe5df0c46274dc0c039
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Tue Jan 9 14:22:38 2024 -0800
    Fix ST_Covers mixed p-i-p case, references #5647
diff --git a/NEWS b/NEWS
index 5cf2268dd..e7a56f002 100644
--- a/NEWS
+++ b/NEWS
@@ -4,7 +4,7 @@ xxxx/xx/xx
 * Bug Fixes *
  - #5610, Regression fix: Allow Nan and infinity again
           in ST_SetPoint (Regina Obe)
- - #5627, Handling of EMPTY components in PiP check (Paul Ramsey)
+ - #5627, #5647, Handling of EMPTY components in PiP check (Paul Ramsey)
  - #5604, Handle distance between collections with empty elements (Paul Ramsey)
  - #5635, Handle NaN points in ST_Split (Regina Obe)
  - Logic error in ST_Covers(geography) (Paul Ramsey)
diff --git a/postgis/lwgeom_geos.c b/postgis/lwgeom_geos.c
index a6fbcd899..4cd0b36a9 100644
--- a/postgis/lwgeom_geos.c
+++ b/postgis/lwgeom_geos.c
@@ -142,7 +142,6 @@ static int
 pip_short_circuit(RTREE_POLY_CACHE *poly_cache, LWPOINT *point, const GSERIALIZED *gpoly)
 	int result;
 	if ( poly_cache && poly_cache->ringIndices )
         result = point_in_multipolygon_rtree(poly_cache->ringIndices, poly_cache->polyCount, poly_cache->ringCounts, point);
@@ -1893,18 +1892,20 @@ Datum contains(PG_FUNCTION_ARGS)
 		else if (gserialized_get_type(gpoint) == MULTIPOINTTYPE)
 			LWMPOINT* mpoint = lwgeom_as_lwmpoint(lwgeom_from_gserialized(gpoint));
-			uint32_t i;
 			int found_completely_inside = LW_FALSE;
 			retval = LW_TRUE;
-			for (i = 0; i < mpoint->ngeoms; i++)
+			for (uint32_t i = 0; i < mpoint->ngeoms; i++)
+				int pip_result;
+				LWPOINT* pt = mpoint->geoms[i];
 				/* We need to find at least one point that's completely inside the
 				 * polygons (pip_result == 1).  As long as we have one point that's
 				 * completely inside, we can have as many as we want on the boundary
 				 * itself. (pip_result == 0)
-				int pip_result = pip_short_circuit(cache, mpoint->geoms[i], gpoly);
+				if (lwpoint_is_empty(pt)) continue;
+				pip_result = pip_short_circuit(cache, pt, gpoly);
 				if (pip_result == 1)
 					found_completely_inside = LW_TRUE;
@@ -2103,8 +2104,9 @@ Datum covers(PG_FUNCTION_ARGS)
 			retval = LW_TRUE;
-				if (pip_result == -1)
+				LWPOINT *pt = mpoint->geoms[i];
+				if (pip_short_circuit(cache, pt, gpoly) == -1)
 					retval = LW_FALSE;
 					break;
@@ -2235,8 +2237,9 @@ Datum coveredby(PG_FUNCTION_ARGS)
 			retval = LW_TRUE;
 					retval = LW_FALSE;
 					break;
@@ -2393,13 +2396,12 @@ Datum ST_Intersects(PG_FUNCTION_ARGS)
-			uint32_t i;
 			retval = LW_FALSE;
-				if (pip_result != -1) /* not outside */
+				if (pip_short_circuit(cache, pt, gpoly) != -1) /* not outside */
 					retval = LW_TRUE;
 					break;
Summary of changes:
 NEWS                  |  2 +-
 postgis/lwgeom_geos.c | 28 +++++++++++++++-------------
 2 files changed, 16 insertions(+), 14 deletions(-)
hooks/post-receive
