[PostGIS] #5650: debbie showing failure on upgrade - ERROR: cannot drop operator @(geometry, geometry) because other objects depend on it (enforce_max_extent_rast_
PostGIS trac at osgeo.org
Tue Jan 9 21:46:10 PST 2024
@(geometry,geometry) because other objects depend on it
  Reporter:  robe     |      Owner:  robe
      Type:  defect   |     Status:  new
  Priority:  blocker  |  Milestone:  PostGIS 3.3.6
 Component:  raster   |    Version:  3.4.x
Resolution:           |   Keywords:
Comment (by Regina Obe <lr@…>):
 In [changeset:"13d4f48d5cee630cc903558be5e7a38ec6879423/git" 13d4f48/git]:
 {{{#!CommitTicketReference repository="git"
 revision="13d4f48d5cee630cc903558be5e7a38ec6879423"
 Revert #5648 fix
 Causing regression failures on PG16 and PG17
 References #5648 and #5650
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5650#comment:7>
