[SCM] PostGIS branch master updated. 3.4.0rc1-879-g841713668
Thu Jan 11 07:22:58 PST 2024
the project "PostGIS".
       via  84171366808536a4662976e50af91321147a06f2 (commit)
       via  809efdc2d9a75749dcea9c54c79965015a6e2ecd (commit)
      from  60795830a15c9c0907f58ed20a21422fbc10eae2 (commit)
revisions in full, below.
commit 84171366808536a4662976e50af91321147a06f2
Author: Sandro Santilli <strk at kbt.io>
Date:   Fri Jan 5 00:52:21 2024 +0100
    woodie: run all tests with standard_conforming_strings off
    Other bots will run the tests without forcing standard_configrming_strings
    See https://trac.osgeo.org/osgeo/ticket/3081#comment:4
diff --git a/.woodpecker/regress.yml b/.woodpecker/regress.yml
index 642b5bb7a..6064250e8 100644
--- a/.woodpecker/regress.yml
+++ b/.woodpecker/regress.yml
@@ -4,7 +4,9 @@ variables:
     - export PATH=/usr/lib/postgresql/$${PGVER}/bin:$${PATH}
     - export PGPORT=$$(grep ^port /etc/postgresql/$${PGVER}/main/postgresql.conf | awk '{print $$3}')
     - export POSTGIS_REGRESS_DB_OWNER=postgis_reg_unprivileged_user
-    - export RUNTESTFLAGS="-v --after-create-db-script $${CI_WORKSPACE}/regress/hooks/configure-pgextwlist.sql"
+    - export RUNTESTFLAGS="-v
+      --after-create-db-script $${CI_WORKSPACE}/regress/hooks/configure-pgextwlist.sql
+      --after-create-db-script $${CI_WORKSPACE}/regress/hooks/standard-conforming-strings-off.sql"
     - export SRCDIR=$${CI_WORKSPACE}
     - export BUILDDIR=$${SRCDIR}/build/pg$${PGVER}
     - export CURRENTVERSION=$$(grep '^POSTGIS_' $${SRCDIR}/Version.config | cut -d= -f2 | paste -sd '.')
@@ -39,10 +41,6 @@ variables:
     - wait # for tee process to flush its buffers
     - echo "-- Summary of upgrade tests --"
     - egrep '(PASS|FAIL|SKIP|INFO|ERROR)' check.log
-    - echo "-- Upgrade tests with standard_conforming_strings off --"
-    - RUNTESTFLAGS="$${RUNTESTFLAGS} --after-create-db-script $${SRCDIR}/regress/hooks/standard-conforming-strings-off.sql"
-      MAKE_ARGS='TESTS=$${SRCDIR}/regress/core/regress'
-      $${SRCDIR}/utils/check_all_upgrades.sh -s :auto!
 clone:
   clone:
commit 809efdc2d9a75749dcea9c54c79965015a6e2ecd
Date:   Thu Jan 11 09:06:11 2024 +0100
    Use escaped string or set standard_conforming_strings=on
    References #5633
diff --git a/postgis/postgis_letters.sql b/postgis/postgis_letters.sql
index 5d924c003..24c0c94fb 100644
--- a/postgis/postgis_letters.sql
+++ b/postgis/postgis_letters.sql
@@ -146,4 +146,5 @@ BEGIN
 END;
 LANGUAGE 'plpgsql'
+SET standard_conforming_strings = ON
 IMMUTABLE _COST_MEDIUM PARALLEL SAFE;
diff --git a/raster/rt_pg/rtpostgis.sql.in b/raster/rt_pg/rtpostgis.sql.in
index 0d00ab36b..d0cb1e952 100644
--- a/raster/rt_pg/rtpostgis.sql.in
+++ b/raster/rt_pg/rtpostgis.sql.in
@@ -6851,7 +6851,7 @@ CREATE OR REPLACE FUNCTION _raster_constraint_info_srid(rastschema name, rasttab
 	SELECT
 		regexp_replace(
 			split_part(s.consrc, ' = ', 2),
-			'[\(\)]', '', 'g'
+			E'[\\(\\)]', '', 'g'
 		)::integer
 	FROM pg_class c, pg_namespace n, pg_attribute a
 		, (SELECT connamespace, conrelid, conkey, pg_get_constraintdef(oid) As consrc
@@ -6925,7 +6925,7 @@ CREATE OR REPLACE FUNCTION _raster_constraint_info_scale(rastschema name, rastta
 				'round(', ''
-			'[ ''''\(\)]', '', 'g'
+			E'[ ''''\\(\\)]', '', 'g'
 		)::text AS val
@@ -7014,7 +7014,7 @@ CREATE OR REPLACE FUNCTION _raster_constraint_info_blocksize(rastschema name, ra
 			ELSE
 				regexp_replace(
 					split_part(s.consrc, '= ', 2),
-					'[\(\)]', '', 'g'
 				)::integer
 			END
@@ -7415,7 +7415,7 @@ CREATE OR REPLACE FUNCTION _raster_constraint_info_num_bands(rastschema name, ra
 	SELECT
 		regexp_replace(
-			'[\(\)]', '', 'g'
 		)::integer
@@ -7484,7 +7484,7 @@ CREATE OR REPLACE FUNCTION _raster_constraint_info_pixel_types(rastschema name,
 			both '''' from split_part(
 				regexp_replace(
-					'[\(\)]', '', 'g'
 				'::', 1
@@ -7571,7 +7571,7 @@ CREATE OR REPLACE FUNCTION _raster_constraint_info_nodata_values(rastschema name
 			split_part(
 				regexp_replace(
-					'[\(\)]', '', 'g'
 				'::', 1
@@ -7664,7 +7664,7 @@ CREATE OR REPLACE FUNCTION _raster_constraint_info_out_db(rastschema name, rastt
 				regexp_replace(
-					'[\(\)]', '', 'g'
 				'::', 1
diff --git a/sfcgal/regress/regress_sfcgal.sql b/sfcgal/regress/regress_sfcgal.sql
index 99141b887..17d6145a0 100644
--- a/sfcgal/regress/regress_sfcgal.sql
+++ b/sfcgal/regress/regress_sfcgal.sql
@@ -20,8 +20,8 @@ ELSE
     regexp_replace(
     regexp_replace(
     ST_AsText(ST_Extrude(ST_Extrude(ST_Extrude('POINT(0 0)', 1, 0, 0), 0, 1, 0), 0, 0, 1)) ,
-    '\(\(0 1 0,1 1 0,1 0 0,0 1 0\)\)', '((1 1 0,1 0 0,0 1 0,1 1 0))'),
-    '\(\(0 1 0,1 0 0,0 0 0,0 1 0\)\)', '((1 0 0,0 0 0,0 1 0,1 0 0))')
+    E'\\(\\(0 1 0,1 1 0,1 0 0,0 1 0\\)\\)', '((1 1 0,1 0 0,0 1 0,1 1 0))'),
+    E'\\(\\(0 1 0,1 0 0,0 0 0,0 1 0\\)\\)', '((1 0 0,0 0 0,0 1 0,1 0 0))')
 END;
 SELECT 'ST_ForceLHR', ST_AsText(ST_ForceLHR('POLYGON((0 0,0 1,1 1,1 0,0 0))'));
Summary of changes:
 .woodpecker/regress.yml           |  8 +++-----
 postgis/postgis_letters.sql       |  1 +
 raster/rt_pg/rtpostgis.sql.in     | 14 +++++++-------
 sfcgal/regress/regress_sfcgal.sql |  4 ++--
 4 files changed, 13 insertions(+), 14 deletions(-)
hooks/post-receive
