[PostGIS] #5633: postgis_extensions_upgrade() breaks and signalize unbalanced parenteses in regex of regexp_replace function
PostGIS trac at osgeo.org
Thu Jan 11 09:16:14 PST 2024
  Reporter:  hci           |      Owner:  strk
      Type:  enhancement   |     Status:  closed
  Priority:  low           |  Milestone:  PostGIS PostgreSQL
 Component:  upgrade/soft  |    Version:  3.3.x
Resolution:  fixed         |   Keywords:  upgrade extensions regexp_replace
Changes (by Sandro Santilli <strk@…>):
 * status:  assigned => closed
 * resolution:   => fixed
Comment:
 In [changeset:"444e5c38e3fe6bcfa14162ccd2df71e4dc3e6353/git" 444e5c3/git]:
 {{{#!CommitTicketReference repository="git"
 revision="444e5c38e3fe6bcfa14162ccd2df71e4dc3e6353"
 Use escaped string or set standard_conforming_strings=on
 Closes #5633 in 3.3 branch (3.3.6dev)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5633#comment:24>
