[PostGIS] #5652: Upgrade raster tests running even if postgis raster is disabled
PostGIS trac at osgeo.org
Fri Jan 12 21:00:17 PST 2024
  Reporter:  robe     |      Owner:  strk
      Type:  defect   |     Status:  closed
  Priority:  blocker  |  Milestone:  PostGIS 3.5.0
 Component:  upgrade  |    Version:  master
Resolution:  fixed    |   Keywords:
Changes (by Regina Obe <lr@…>):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"8619e4da76e068c94327613a3196c73911f82b0c/git" 8619e4d/git]:
 {{{#!CommitTicketReference repository="git"
 revision="8619e4da76e068c94327613a3196c73911f82b0c"
 Make sure rtpostgis_ugprade.sql gets built
 during upgrade tests
 Even if raster is disabled
 Closes #5652
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5652#comment:3>
