[SCM] PostGIS branch master updated. 3.4.0rc1-884-g8489655ed
Wed Jan 17 16:34:09 PST 2024
the project "PostGIS".
       via  8489655ed88134a4478121041dbdb9ead12f6868 (commit)
      from  dd88d87cfc3b7b7b7f059171fb090ee4b2db8836 (commit)
revisions in full, below.
commit 8489655ed88134a4478121041dbdb9ead12f6868
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Wed Jan 17 16:34:04 2024 -0800
    Improve performance of ST_GeneratePoints by... not using lwcollection_add_lwgeom()
    Apparently, for reasons not entirely clear, it is quite inefficient.
    In adding 50000 points to an empty multipoint with the function
    a solid 1000 ms of return time was from the collection filler, which
    is very large.
diff --git a/NEWS b/NEWS
index fa5958806..9679ccf22 100644
--- a/NEWS
+++ b/NEWS
@@ -49,6 +49,7 @@ To take advantage of all SFCGAL featurs, SFCGAL 1.5.0+ is needed.
   - GH-744, Don't create docbook.css for the HTML manual,
             use style.css instead (Chris Mayo)
   - Faster implementation of point-in-poly cached index (Paul Ramsey)
+  - Improve performance of ST_GeneratePoints (Paul Ramsey)
 PostGIS 3.4.0
diff --git a/liblwgeom/lwgeom_geos.c b/liblwgeom/lwgeom_geos.c
index 1c662d6e6..56eca41f3 100644
--- a/liblwgeom/lwgeom_geos.c
+++ b/liblwgeom/lwgeom_geos.c
@@ -29,6 +29,7 @@
 #include "liblwgeom_internal.h"
 #include "lwgeom_log.h"
 #include "lwrandom.h"
+#include "profile.h"
 #include <stdarg.h>
 #include <stdlib.h>
@@ -1400,7 +1401,7 @@ lwgeom_offsetcurve(const LWGEOM* geom, double size, int quadsegs, int joinStyle,
 static GEOSGeometry*
-lwpoly_to_points_makepoly(double xmin, double ymin, double cell_size)
+lwpoly_to_points_make_cell(double xmin, double ymin, double cell_size)
 	GEOSCoordSequence *cs = GEOSCoordSeq_create(5, 2);
 	GEOSCoordSeq_setXY(cs, 0, xmin, ymin);
@@ -1437,7 +1438,7 @@ lwpoly_to_points(const LWPOLY* lwpoly, uint32_t npoints, int32_t seed)
 	LWMPOINT* mpt;
 	int32_t srid = lwgeom_get_srid(lwgeom);
 	int done = 0;
+	LWPOINT **points_generated;
 	if (lwgeom_get_type(lwgeom) != POLYGONTYPE)
@@ -1502,12 +1503,14 @@ lwpoly_to_points(const LWPOLY* lwpoly, uint32_t npoints, int32_t seed)
 	gprep = GEOSPrepare(g);
+	/* START_PROFILING(); */
 	/* Now we fill in an array of cells, only using cells that actually
 	 * intersect the geometry of interest, and finally weshuffle that array,
 	 * so we can visit the cells in random order to avoid visual ugliness
 	 * caused by visiting them sequentially */
 	cells = lwalloc(sizeof(CellCorner) * sample_height * sample_width);
 	for (i = 0; i < sample_width; i++)
 		for (j = 0; j < sample_height; j++)
@@ -1515,11 +1518,11 @@ lwpoly_to_points(const LWPOLY* lwpoly, uint32_t npoints, int32_t seed)
 			int intersects = 0;
 			double xmin = bbox.xmin + i * sample_cell_size;
 			double ymin = bbox.ymin + j * sample_cell_size;
-			GEOSGeometry *gcell = lwpoly_to_points_makepoly(xmin, ymin, sample_cell_size);
+			GEOSGeometry *gcell = lwpoly_to_points_make_cell(xmin, ymin, sample_cell_size);
 			intersects = GEOSPreparedIntersects(gprep, gcell);
+			GEOSGeom_destroy(gcell);
 			if (intersects == 2)
-				GEOSGeom_destroy(gcell);
 				GEOSPreparedGeom_destroy(gprep);
 				GEOSGeom_destroy(g);
 				lwerror("%s: GEOS exception on GEOSPreparedIntersects: %s", __func__, lwgeom_geos_errmsg);
@@ -1531,10 +1534,11 @@ lwpoly_to_points(const LWPOLY* lwpoly, uint32_t npoints, int32_t seed)
 				cells[num_cells].y = ymin;
 				num_cells++;
+	/* STOP_PROFILING(CellGeneration); */
 	/* Initiate random number generator.
 	 * Repeatable numbers are generated with seed values >= 1.
 	 * When seed is zero and has not previously been set, it is based on
@@ -1555,8 +1559,8 @@ lwpoly_to_points(const LWPOLY* lwpoly, uint32_t npoints, int32_t seed)
-	/* Get an empty multi-point ready to return */
-	mpt = lwmpoint_construct_empty(srid, 0, 0);
+	/* Get an empty array of points ready to return */
+	points_generated = lwalloc0(sizeof(LWGEOM*)*npoints);
 	/* Start testing points */
 	while (npoints_generated < npoints)
@@ -1583,7 +1587,6 @@ lwpoly_to_points(const LWPOLY* lwpoly, uint32_t npoints, int32_t seed)
 				GEOSGeom_destroy(gpt);
 #endif
 			if (contains == 2)
@@ -1593,8 +1596,7 @@ lwpoly_to_points(const LWPOLY* lwpoly, uint32_t npoints, int32_t seed)
 			if (contains == 1)
-				npoints_generated++;
-				mpt = lwmpoint_add_lwpoint(mpt, lwpoint_make2d(srid, x, y));
+				points_generated[npoints_generated++] = lwpoint_make2d(srid, x, y);
 				if (npoints_generated == npoints)
 					done = 1;
@@ -1616,6 +1618,13 @@ lwpoly_to_points(const LWPOLY* lwpoly, uint32_t npoints, int32_t seed)
 	lwfree(cells);
+	mpt = lwalloc0(sizeof(LWMPOINT));
+	mpt->type = MULTIPOINTTYPE;
+	mpt->geoms = points_generated;
+	mpt->ngeoms = npoints_generated;
+	mpt->maxgeoms = npoints;
+	mpt->srid = srid;
 	return mpt;
diff --git a/liblwgeom/lwgeom_geos_clean.c b/liblwgeom/lwgeom_geos_clean.c
index 7eb1e907e..219a9f4fb 100644
--- a/liblwgeom/lwgeom_geos_clean.c
+++ b/liblwgeom/lwgeom_geos_clean.c
@@ -36,7 +36,6 @@
 #include <assert.h>
 /* #define PARANOIA_LEVEL 2 */
-#undef LWGEOM_PROFILE_MAKEVALID
 LWGEOM* lwcollection_make_geos_friendly(LWCOLLECTION* g);
 LWGEOM* lwline_make_geos_friendly(LWLINE* line);
diff --git a/liblwgeom/profile.h b/liblwgeom/profile.h
new file mode 100644
index 000000000..d4b57e390
--- /dev/null
+++ b/liblwgeom/profile.h
@@ -0,0 +1,17 @@
+#include "liblwgeom.h"
+#include <time.h>
+static clock_t start_time, end_time;
+static double cpu_time_used;
+ * A convenience macro for performance testing and breaking
+ * down what time is spent where.
+#define START_PROFILING() do { start_time = clock(); } while(0)
+#define END_PROFILING(name) do { \
+	end_time = clock(); \
+	cpu_time_used = ((double) (end_time - start_time)) / CLOCKS_PER_SEC; \
+	lwnotice("Time used for " #name ": %f secs\n", cpu_time_used); \
+} while(0)
Summary of changes:
 NEWS                          |  1 +
 liblwgeom/lwgeom_geos.c       | 29 +++++++++++++++++++----------
 liblwgeom/lwgeom_geos_clean.c |  1 -
 liblwgeom/profile.h           | 17 +++++++++++++++++
 4 files changed, 37 insertions(+), 11 deletions(-)
 create mode 100644 liblwgeom/profile.h
hooks/post-receive
