[SCM] PostGIS branch master updated. 3.4.0rc1-888-g0455f7270
    git at osgeo.org
    git at osgeo.org
    Fri Jan 19 11:49:54 PST 2024
the project "PostGIS".
       via  0455f7270e007aeeb743ecb5dfa314dc73b7a6f7 (commit)
      from  c5730e6c921d55bc178d1dfc7ecf40962d5e0a47 (commit)
revisions in full, below.
commit 0455f7270e007aeeb743ecb5dfa314dc73b7a6f7
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Fri Jan 19 11:49:19 2024 -0800
    Remove the PARANOIA define
    and change over to using assert when possible
    and ifndef NDEBUG blocks otherwise.
    Add --enable-assert configure option
    for those who want all runtime checks
    turned on, and "full debug" CI jobs.
diff --git a/ci/github/run_debug.sh b/ci/github/run_debug.sh
index f3b742afd..bc709dfd4 100644
--- a/ci/github/run_debug.sh
+++ b/ci/github/run_debug.sh
@@ -2,7 +2,8 @@
 set -e
 ./autogen.sh
-# Check that compilation works at nonzero POSTGIS_DEBUG_LEVEL
-./configure --enable-debug # sets PARANOIA_LEVEL
+# Check that compilation works with all checks
+# enabled
+./configure --enable-debug --enable-assert
 sed -i 's/POSTGIS_DEBUG_LEVEL [0-9]$/POSTGIS_DEBUG_LEVEL 4/' postgis_config.h
 make -j
diff --git a/configure.ac b/configure.ac
index 23ebf55c8..74808d679 100644
--- a/configure.ac
+++ b/configure.ac
@@ -1300,9 +1300,12 @@ dnl Allow the developer to turn on expensive checks and debugging flags
 dnl with --enable-debug
 dnl
-AC_ARG_ENABLE([debug], AS_HELP_STRING([--enable-debug], [Enable debugging code and flags]),
+AC_ARG_ENABLE([debug], AS_HELP_STRING([--enable-debug], [Enable debugging flags]),
 	[ENABLE_DEBUG=1], [ENABLE_DEBUG=0])
+AC_ARG_ENABLE([assert], AS_HELP_STRING([--enable-assert], [Enable assertions and expensive correctness checks]),
+	[ENABLE_ASSERT=1], [ENABLE_ASSERT=0])
 dnl Allow the developer to turn on link time optimization is supported by compiler
 dnl with --enable-lto (for non-debug build)
 AC_ARG_ENABLE(
@@ -1318,17 +1321,22 @@ AC_ARG_ENABLE(
 dnl Add -Wall to CFLAGS
 _LT_COMPILER_OPTION([if $compiler supports -Wall], [_cv_wall], [-Wall], [], [CFLAGS="$CFLAGS -Wall"], [])
+dnl We only turn on link-time optimizations for full production builds
+dnl because they make debugger use problematic
 if test $ENABLE_DEBUG -eq 1; then
-    AC_DEFINE([PARANOIA_LEVEL], [10], [Enable use of memory checks])
-    CFLAGS="$CFLAGS -g"
+  CFLAGS="$CFLAGS -g"
 else
-    AC_DEFINE([PARANOIA_LEVEL], [0], [Disable use of memory checks])
-    CPPFLAGS="-DNDEBUG $CPPFLAGS"
+  CFLAGS="$CFLAGS -O2"
+  if test $ENABLE_LTO -eq 1; then
+    _LT_COMPILER_OPTION([if $compiler supports -flto],[_cv_flto],[-flto],[],[CFLAGS="$CFLAGS -flto"],[])
+    _LT_LINKER_OPTION([if $compiler supports -flto],[_cv_flto],[[-flto]],[LDFLAGS="$LDFLAGS -flto"])
+  fi
+fi
-    if test $ENABLE_LTO -eq 1; then
-        _LT_COMPILER_OPTION([if $compiler supports -flto],[_cv_flto],[-flto],[],[CFLAGS="$CFLAGS -flto"],[])
-        _LT_LINKER_OPTION([if $compiler supports -flto],[_cv_flto],[[-flto]],[LDFLAGS="$LDFLAGS -flto"])
-    fi
+dnl If asserts are not requested, we need to disable them
+dnl and other safety checks with NDEBUG
+if test $ENABLE_ASSERT -eq 0; then
+  CPPFLAGS="-DNDEBUG $CPPFLAGS"
 fi
 AC_DEFINE([POSTGIS_DEBUG_LEVEL], [0], [Define debug level. Default 0])
diff --git a/liblwgeom/lwcollection.c b/liblwgeom/lwcollection.c
index 2cba81c1b..53b3877d2 100644
--- a/liblwgeom/lwcollection.c
+++ b/liblwgeom/lwcollection.c
@@ -212,12 +212,11 @@ LWCOLLECTION* lwcollection_add_lwgeom(LWCOLLECTION *col, const LWGEOM *geom)
 	/* Allocate more space if we need it */
 	lwcollection_reserve(col, col->ngeoms + 1);
-#if PARANOIA_LEVEL > 1
+#ifndef NDEBUG
 	/* See http://trac.osgeo.org/postgis/ticket/2933 */
 	/* Make sure we don't already have a reference to this geom */
-		uint32_t i = 0;
-		for (i = 0; i < col->ngeoms; i++)
+		for (uint32_t i = 0; i < col->ngeoms; i++)
 			if (col->geoms[i] == geom)
diff --git a/liblwgeom/lwgeom_api.c b/liblwgeom/lwgeom_api.c
index e966251d5..0ef5a103f 100644
--- a/liblwgeom/lwgeom_api.c
+++ b/liblwgeom/lwgeom_api.c
@@ -647,9 +647,7 @@ deparse_hex(uint8_t str, char *result)
 void
 interpolate_point4d(const POINT4D *A, const POINT4D *B, POINT4D *I, double F)
-#if PARANOIA_LEVEL > 0
-	if (F < 0 || F > 1) lwerror("interpolate_point4d: invalid F (%g)", F);
-#endif
+	assert(F >= 0 && F <= 1);
 	I->x=A->x+((B->x-A->x)*F);
 	I->y=A->y+((B->y-A->y)*F);
 	I->z=A->z+((B->z-A->z)*F);
diff --git a/liblwgeom/lwgeom_geos.c b/liblwgeom/lwgeom_geos.c
index ea4506ca7..368a53b55 100644
--- a/liblwgeom/lwgeom_geos.c
+++ b/liblwgeom/lwgeom_geos.c
@@ -29,7 +29,6 @@
 #include "liblwgeom_internal.h"
 #include "lwgeom_log.h"
 #include "lwrandom.h"
-#include "profile.h"
 #include <stdarg.h>
 #include <stdlib.h>
diff --git a/liblwgeom/lwgeom_geos_split.c b/liblwgeom/lwgeom_geos_split.c
index 83038a485..901a1ac14 100644
--- a/liblwgeom/lwgeom_geos_split.c
+++ b/liblwgeom/lwgeom_geos_split.c
@@ -414,7 +414,7 @@ lwpoly_split_by_line(const LWPOLY* lwpoly_in, const LWGEOM* blade_in)
 		return NULL;
+#ifndef NDEBUG
 	if ( GEOSGeomTypeId(polygons) != COLLECTIONTYPE )
 		GEOSGeom_destroy(g1);
diff --git a/liblwgeom/lwgeom_median.c b/liblwgeom/lwgeom_median.c
index 0ff90f66a..5db5d2a78 100644
--- a/liblwgeom/lwgeom_median.c
+++ b/liblwgeom/lwgeom_median.c
@@ -171,12 +171,11 @@ init_guess(const POINT4D* points, uint32_t npoints)
 POINT4D*
 lwmpoint_extract_points_4d(const LWMPOINT* g, uint32_t* npoints, int* input_empty)
-	uint32_t i;
 	uint32_t n = 0;
 	POINT4D* points = lwalloc(g->ngeoms * sizeof(POINT4D));
 	int has_m = lwgeom_has_m((LWGEOM*) g);
-	for (i = 0; i < g->ngeoms; i++)
+	for (uint32_t i = 0; i < g->ngeoms; i++)
 		LWGEOM* subg = lwcollection_getsubgeom((LWCOLLECTION*) g, i);
 		if (!lwgeom_is_empty(subg))
@@ -217,9 +216,11 @@ lwmpoint_extract_points_4d(const LWMPOINT* g, uint32_t* npoints, int* input_empt
-	/* check Z=0 for 2D inputs*/
-	if (!lwgeom_has_z((LWGEOM*) g)) for (i = 0; i < n; i++) assert(points[i].z == 0);
+#ifndef NDEBUG
+	/* check Z=0 for 2D inputs */
+	if (!lwgeom_has_z((LWGEOM*) g))
+		for (uint32_t i = 0; i < n; i++)
+			assert(points[i].z == 0);
 #endif
 	*npoints = n;
diff --git a/liblwgeom/lwinline.h b/liblwgeom/lwinline.h
index 47e6aaeb9..0d874cb13 100644
--- a/liblwgeom/lwinline.h
+++ b/liblwgeom/lwinline.h
@@ -27,9 +27,7 @@
 #include <assert.h>
-#endif
 inline static double
 distance2d_sqr_pt_pt(const POINT2D *p1, const POINT2D *p2)
@@ -79,11 +77,9 @@ getPoint_internal(const POINTARRAY *pa, uint32_t n)
 	size_t size;
 	uint8_t *ptr;
 	assert(pa);
 	assert(n <= pa->npoints);
 	assert(n <= pa->maxpoints);
-#endif
 	size = ptarray_point_size(pa);
 	ptr = pa->serialized_pointlist + size * n;
diff --git a/liblwgeom/lwlinearreferencing.c b/liblwgeom/lwlinearreferencing.c
index 35628bf19..610f0cf4e 100644
--- a/liblwgeom/lwlinearreferencing.c
+++ b/liblwgeom/lwlinearreferencing.c
@@ -327,22 +327,10 @@ point_interpolate(const POINT4D *p1,
 	double proportion;
 	int i = 0;
-	if (!(ordinate == 'X' || ordinate == 'Y' || ordinate == 'Z' || ordinate == 'M'))
-		lwerror("Cannot interpolate over %c ordinate.", ordinate);
-		return LW_FAILURE;
-	if (FP_MIN(p1_value, p2_value) > interpolation_value || FP_MAX(p1_value, p2_value) < interpolation_value)
-		lwerror("Cannot interpolate to a value (%g) not between the input points (%g, %g).",
-			interpolation_value,
-			p1_value,
-			p2_value);
-#endif
+	assert(ordinate == 'X' || ordinate == 'Y' ||
+	       ordinate == 'Z' || ordinate == 'M');
+	assert(FP_MIN(p1_value, p2_value) <= interpolation_value &&
+	       FP_MAX(p1_value, p2_value) >= interpolation_value);
 	proportion = (interpolation_value - p1_value) / (p2_value - p1_value);
diff --git a/liblwgeom/profile.h b/liblwgeom/profile.h
deleted file mode 100644
index d4b57e390..000000000
--- a/liblwgeom/profile.h
+++ /dev/null
@@ -1,17 +0,0 @@
-#include "liblwgeom.h"
-#include <time.h>
-static clock_t start_time, end_time;
-static double cpu_time_used;
- * A convenience macro for performance testing and breaking
- * down what time is spent where.
-#define START_PROFILING() do { start_time = clock(); } while(0)
-#define END_PROFILING(name) do { \
-	end_time = clock(); \
-	cpu_time_used = ((double) (end_time - start_time)) / CLOCKS_PER_SEC; \
-	lwnotice("Time used for " #name ": %f secs\n", cpu_time_used); \
-} while(0)
diff --git a/liblwgeom/ptarray.c b/liblwgeom/ptarray.c
index 86454313c..e4bb380ce 100644
--- a/liblwgeom/ptarray.c
+++ b/liblwgeom/ptarray.c
@@ -578,20 +578,8 @@ ptarray_removePoint(POINTARRAY *pa, uint32_t which)
 	LWDEBUGF(3, "pa %x which %d", pa, which);
-	if ( which > pa->npoints-1 )
-		lwerror("%s [%d] offset (%d) out of range (%d..%d)", __FILE__, __LINE__,
-		        which, 0, pa->npoints-1);
-		return NULL;
-	if ( pa->npoints < 3 )
-		lwerror("%s [%d] can't remove a point from a 2-vertex POINTARRAY", __FILE__, __LINE__);
-		return NULL;
-#endif
+	assert(which <= pa->npoints-1);
+	assert(pa->npoints >= 3);
 	ret = ptarray_construct(FLAGS_GET_Z(pa->flags),
 	                        FLAGS_GET_M(pa->flags), pa->npoints-1);
diff --git a/postgis_config.h.in b/postgis_config.h.in
index a439f55cc..f94d5a061 100644
--- a/postgis_config.h.in
+++ b/postgis_config.h.in
@@ -7,9 +7,6 @@
    configure process */
 #define POSTGIS_DEBUG_LEVEL 0
-/* Define to 1 to enable memory checks in pointarray management. */
-#undef PARANOIA_LEVEL
 /* Define to 1 if translation of program messages to the user's native
    language is requested. */
 #undef ENABLE_NLS
Summary of changes:
 ci/github/run_debug.sh          |  5 +++--
 configure.ac                    | 26 +++++++++++++++++---------
 liblwgeom/lwcollection.c        |  5 ++---
 liblwgeom/lwgeom_api.c          |  4 +---
 liblwgeom/lwgeom_geos.c         |  1 -
 liblwgeom/lwgeom_geos_split.c   |  2 +-
 liblwgeom/lwgeom_median.c       | 11 ++++++-----
 liblwgeom/lwinline.h            |  4 ----
 liblwgeom/lwlinearreferencing.c | 20 ++++----------------
 liblwgeom/profile.h             | 17 -----------------
 liblwgeom/ptarray.c             | 16 ++--------------
 postgis_config.h.in             |  3 ---
 12 files changed, 36 insertions(+), 78 deletions(-)
 delete mode 100644 liblwgeom/profile.h
hooks/post-receive
