[PostGIS] #5639: ST_DFullyWithin fails when dealing with LINESTRING and POLYGON
PostGIS trac at osgeo.org
Fri Jan 19 15:46:44 PST 2024
  Reporter:  Wenjing  |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 3.4.2
 Component:  postgis  |    Version:  3.4.x
Resolution:           |   Keywords:
Comment (by pramsey):
 This is quite bad one, basically handling of max distance for objects that
 overlap is quite bad.
 SELECT ST_MaxDistance(a1, a2)
 FROM (VALUES
   ('POINT(0.5 0.5)', 'POLYGON((0 0, 0 1, 1 1, 1 0, 0 0))')
   ) AS a(a1, a2);
 FROM (VALUES
   ('POINT(1.5 1.5)', 'POLYGON((0 0, 0 1, 1 1, 1 0, 0 0))')
   ) AS a(a1, a2);
 FROM (VALUES
   ('LINESTRING(0.5 0.5, 1.1 1.1)', 'POLYGON((0 0, 0 1, 1 1, 1 0, 0 0))')
   ) AS a(a1, a2);
 FROM (VALUES
   ('LINESTRING(0.5 0.5, 1.5 1.5)', 'POLYGON((0 0, 0 1, 1 1, 1 0, 0 0))')
   ) AS a(a1, a2);
 FROM (VALUES
   ('LINESTRING(1.5 1.5, 0.5 0.5)', 'POLYGON((0 0, 0 1, 1 1, 1 0, 0 0))')
   ) AS a(a1, a2);
 And this is without getting into really fun cases where the largest
 distance is found at a vertex in a hole, for example.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5639#comment:3>
