[SCM] PostGIS branch master updated. 3.4.0rc1-890-g5b2ae9ff0
Sat Jan 20 12:37:08 PST 2024
the project "PostGIS".
       via  5b2ae9ff058387de2a0b015181190ded0b37b12a (commit)
      from  d2e93ca0dccdb7230ba356643585157595a208bb (commit)
revisions in full, below.
commit 5b2ae9ff058387de2a0b015181190ded0b37b12a
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Sat Jan 20 12:37:03 2024 -0800
    Correctly handle max distance for point/polygon case, avoiding returning distance to points that are contained in the polygon (distance == 0). References #5639
diff --git a/liblwgeom/measures.c b/liblwgeom/measures.c
index b22b2cca1..240b39bc6 100644
--- a/liblwgeom/measures.c
+++ b/liblwgeom/measures.c
@@ -238,6 +238,17 @@ lw_dist2d_comp(const LWGEOM *lw1, const LWGEOM *lw2, DISTPTS *dl)
 	return lw_dist2d_recursive(lw1, lw2, dl);
+static int
+lw_dist2d_zero(DISTPTS *dl, const POINT2D *pt1, const POINT2D *pt2)
+	dl->distance = 0.0;
+	if (pt1)
+		dl->p1 = *pt1;
+	if (pt2)
+		dl->p2 = *pt2;
+	return LW_TRUE;
 static int
 lw_dist2d_is_collection(const LWGEOM *g)
@@ -642,10 +653,6 @@ lw_dist2d_point_poly(LWPOINT *point, LWPOLY *poly, DISTPTS *dl)
 	const POINT2D *p = getPoint2d_cp(point->point, 0);
-	/* Max distance? Check only outer ring.*/
-	if (dl->mode == DIST_MAX)
-		return lw_dist2d_pt_ptarray(p, poly->rings[0], dl);
 	/* Return distance to outer ring if not inside it */
 	if (ptarray_contains_point(poly->rings[0], p) == LW_OUTSIDE)
@@ -661,10 +668,7 @@ lw_dist2d_point_poly(LWPOINT *point, LWPOLY *poly, DISTPTS *dl)
 			return lw_dist2d_pt_ptarray(p, poly->rings[i], dl);
 	/* Is inside the polygon */
-	dl->distance = 0.0;
-	dl->p1.x = dl->p2.x = p->x;
-	dl->p1.y = dl->p2.y = p->y;
-	return LW_TRUE;
+	return lw_dist2d_zero(dl, p, p);
 int
@@ -762,12 +766,7 @@ lw_dist2d_line_poly(LWLINE *line, LWPOLY *poly, DISTPTS *dl)
 	/* Not in hole, so inside polygon */
 	if (dl->mode == DIST_MIN)
-		dl->p1.x = dl->p2.x = pt->x;
-		dl->p1.y = dl->p2.y = pt->y;
-	return LW_TRUE;
 int
Summary of changes:
 liblwgeom/measures.c | 27 +++++++++++++--------------
 1 file changed, 13 insertions(+), 14 deletions(-)
hooks/post-receive
