[PostGIS] #5639: ST_DFullyWithin fails when dealing with LINESTRING and POLYGON
PostGIS trac at osgeo.org
Tue Jan 23 09:35:25 PST 2024
  Reporter:  Wenjing  |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 3.4.2
 Component:  postgis  |    Version:  3.4.x
Resolution:           |   Keywords:
Comment (by pramsey):
 So, this ticket is still valid, though hopefully the fix is more of a
 special case change than a major re-work. The max distance mode needs a
 lot more test cases to prove it works as documented (max distance between
 vertices, no special handling for rings/areas).
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5639#comment:12>
