[SCM] PostGIS branch stable-3.2 updated. 3.2.6-20-gb2e5dc8d0
Tue Jan 23 14:00:34 PST 2024
the project "PostGIS".
The branch, stable-3.2 has been updated
       via  b2e5dc8d0d5f1721f1b2dac012226e51ea7153ef (commit)
      from  790c7bdffda0afd6c1f9ad615b58312e5a6b4aca (commit)
revisions in full, below.
commit b2e5dc8d0d5f1721f1b2dac012226e51ea7153ef
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Tue Jan 23 14:00:29 2024 -0800
    Do full ring check always in line/poly maxdist mode, references #5639
diff --git a/NEWS b/NEWS
index 70430f2de..0ee058cf6 100644
--- a/NEWS
+++ b/NEWS
@@ -16,6 +16,7 @@ Proj 6.1+, and PostgreSQL 14+.
  - Logic error in ST_Covers(geography) (Paul Ramsey)
  - #5646, Crash on collections with empty members (Paul Ramsey)
  - #5580, Handle empty collection components in 3d distance (Paul Ramsey)
+ - #5639, ST_DFullyWithin line/poly error case (Paul Ramsey)
 PostGIS 3.2.6
diff --git a/liblwgeom/measures.c b/liblwgeom/measures.c
index 2484e9d16..ac2ddac46 100644
--- a/liblwgeom/measures.c
+++ b/liblwgeom/measures.c
@@ -742,7 +742,7 @@ lw_dist2d_line_poly(LWLINE *line, LWPOLY *poly, DISTPTS *dl)
 	const POINT2D *pt = getPoint2d_cp(pa, 0);
 	/* Line has a pount outside poly. Check distance to outer ring only. */
-	if (ptarray_contains_point(poly->rings[0], pt) == LW_OUTSIDE)
+	if (ptarray_contains_point(poly->rings[0], pt) == LW_OUTSIDE || dl->mode == DIST_MAX)
 		return lw_dist2d_ptarray_ptarray(pa, poly->rings[0], dl);
 	for (uint32_t i = 1; i < poly->nrings; i++)
Summary of changes:
 NEWS                 | 1 +
 liblwgeom/measures.c | 2 +-
 2 files changed, 2 insertions(+), 1 deletion(-)
hooks/post-receive
