[PostGIS] #5660: debbie doc building and dist building broken
PostGIS trac at osgeo.org
Fri Jan 26 08:40:53 PST 2024
 Reporter:  robe           |      Owner:  robe
     Type:  defect         |     Status:  new
 Priority:  blocker        |  Milestone:  PostGIS 3.5.0
Component:  documentation  |    Version:  master
 Keywords:                 |
 I noticed this has been failing since yesterday as of commit
 [f5d6c10b7/git]
 14:13:12 /usr/bin/xmllint --path
 .:/var/lib/jenkins/workspace/PostGIS_Make_Dist/label/debbie/89cb3c8048d2fbdf3dd26dfa5f07a223942104fd/doc
 --noent -o postgis-nospecial.xml postgis-nospecial.xml.in
 14:13:12 reference_accessor.xml:3109: parser error : Entity
 'sqlmm_konform' not defined
 14:13:12 >&sqlmm_konform; SQL-MM ISO/IEC 13249-3: 8.5</para>
 14:13:12                 ^
 14:13:12 reference_accessor.xml:3246: parser error : Entity
 14:13:12                 ^
 14:13:12 reference_accessor.xml:4155: parser error : chunk is not well
 balanced
 14:13:12
 14:13:12 ^
 14:13:12 reference.xml:13: parser error : Entity 'reference_accessor'
 failed to parse
 14:13:12 erence_type; &reference_management; &reference_constructor;
 &reference_accessor;
 14:13:12
 14:13:12 reference.xml:13: parser error : chunk is not well balanced
 14:13:12 tion; &reference_version; &reference_guc;
 &reference_troubleshooting; </chapter>
 14:13:12
 14:13:12 postgis-nospecial.xml.in:181: parser error : Entity 'reference'
 failed to parse
 14:13:12   &reference;
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5660>
