[SCM] PostGIS branch master updated. 3.4.0rc1-903-g0a4e38e4a
Fri Jan 26 10:37:54 PST 2024
the project "PostGIS".
       via  0a4e38e4ad79cc8367d6db3431d4e4d9b90e07b2 (commit)
      from  89cb3c8048d2fbdf3dd26dfa5f07a223942104fd (commit)
revisions in full, below.
commit 0a4e38e4ad79cc8367d6db3431d4e4d9b90e07b2
Author: Regina Obe <lr at pcorp.us>
Date:   Fri Jan 26 13:37:51 2024 -0500
    Update pot
diff --git a/doc/po/templates/postgis-manual.pot b/doc/po/templates/postgis-manual.pot
index 059924d9c..1bba309e8 100644
--- a/doc/po/templates/postgis-manual.pot
+++ b/doc/po/templates/postgis-manual.pot
@@ -6,7 +6,7 @@ msgid ""
 msgstr ""
 "Project-Id-Version: PACKAGE VERSION\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
-"POT-Creation-Date: 2023-12-27 04:20+0000\n"
+"POT-Creation-Date: 2024-01-26 18:34+0000\n"
 "PO-Revision-Date: YEAR-MO-DA HO:MI+ZONE\n"
 "Last-Translator: FULL NAME <EMAIL at ADDRESS>\n"
 "Language-Team: LANGUAGE <kde-i18n-doc at kde.org>\n"
@@ -7887,6 +7887,11 @@ msgstr ""
 msgid "Charlie Savage"
 msgstr ""
+#. Tag: member
+#, no-c-format
+msgid "Chris Mayo"
+msgstr ""
 #. Tag: member
 #, no-c-format
 msgid "Christian Schroeder"
@@ -8469,6 +8474,11 @@ msgstr ""
 msgid "Hunter Systems Group"
 msgstr ""
+#. Tag: link
+#, no-c-format
+msgid "INIA-CSIC"
+msgstr ""
 #. Tag: link
 #, no-c-format
 msgid "ISciences, LLC"
@@ -31020,17 +31030,26 @@ msgstr ""
 #. Tag: refpurpose
 #, no-c-format
-msgid "Tests if two geometries are entirely within a given distance"
+msgid "Tests if a geometry is entirely inside a distance of another"
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
-"Returns true if the geometries are entirely within the specified distance of "
-"one another. The distance is specified in units defined by the spatial "
-"reference system of the geometries. For this function to make sense, the "
-"source geometries must both be of the same coordinate projection, having the "
-"same SRID."
+"Returns true if <code>g2</code> is entirely within <code>distance</code> of "
+"<code>g1</code>. Visually, the condition is true if <code>g2</code> is "
+"contained within a <code>distance</code> buffer of <code>g1</code>. The "
+"distance is specified in units defined by the spatial reference system of "
+"the geometries."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Changed: 3.5.0 : the logic behind the function now uses a test of "
+"containment within a buffer, rather than the ST_MaxDistance algorithm. "
+"Results will differ from prior versions, but should be closer to user "
+"expectations."
 msgstr ""
 #. Tag: para
Summary of changes:
 doc/po/templates/postgis-manual.pot | 33 ++++++++++++++++++++++++++-------
 1 file changed, 26 insertions(+), 7 deletions(-)
hooks/post-receive
